Hello all,
I'm currently building this design:
It will be powered by an ep2500. I feel like this amplifier is overkill. However the ep1500 isn't cheap enough for me to justify the difference. Do any of you have better recomendations?
There is a lot of discussion in the thread about a few points:
1. They recomend OC705 or 8lb Rock wool. Both are hard to get for me but I've found a source for OC705. It's a bit expensive however. Does anyone have any ideas on a better/cheaper/more easily sourced material?
2. The designer recomends the DCX2496 to act as a digital crossover. He recomends a second order highpass filter at 20Hz to protect the subwoofer from frequencies below that level. This unit is also a bit too expensive for my tastes. I will be buying the UMC-1 from emotiva when I get my Statements finished. This unit has a balanced subwoofer output. I am still a bit new to the game and have been unable to determine if the emotiva will allow me to set both a high pass and low pass filter and at what levels. Basically, do I need the DCX2496?
Thanks!
Thanks!
