I just wanted to pass along some info that may be useful for those here that dabble in audio electronics and active crossovers.
I came across an old IC made by Exar called the XR2206 that still happens to be in production. It is a 16 pin IC that is a monolithic function generator with many additional features. It is a $2 chip that can create low distortion sine, square, and triangle waves of constant amplitude with variable frequency using a single potentiometer. It also has built in AM and FM modulation.
While a modern PC is perfectly fine for generating sine waves in the audio band, the XR2206 can function from 0.1Hz up to 1MHz (although I have found that above 100KHz the 1% sine wave distortion spec is not accurate).
If anyone needs a frequency generator (for instance it might be of use in the H@LF project posted here on HTGuide) this is a very easy to use (and cheap!) solution. I was able to rig up an amplitude modulation system using two chips and parts from my grab box of electronics (nothing that you can't find at Radio Shack).
Back in the day these types of IC's were common, but the Exar is the only one that I have found that is still in production.
