Reality check for a modified Neo concept
    • 5673
    Question re the Neo:
    Does anybody think it would be possible to build the Neo with an integrated bass bin?
    I was day-dreaming about this and came up with a two compartment tower config using the 40 liter volume in the top section for the Neo, and possibly the TB W8Q-1071F http://www.partsexpress.com/pdf/264-838s.pdf in the bottom bass chamber.
    This would allow keeping the 9” baffle width and its associated foot print while integrating a bass driver in the same cabinet. Could this TB driver be made to cross over at anything above 150 Hz?
    Adding bass bins or a sub with a 40-60 liter Neo is not going to pas the dreaded WAF, and she is already V patient me, my NatP 68 Liter towers and the rest of my current system that dominates our LR.
    TIA, Guys
    I have dual RSS285 to be used in each bass bin for my NeoDcc mains.
    Using side firing woofer/woofers and a 100Hz XO point the front baffle can be kept narrow.
    Oval speakers represent a compromise because the shape of the cone and resistance of the suspension isn't symmetrical, so from the get-go they're inherently less linear/pistonic than a round speaker
      • 16073
      Yeah I was going to say just go side mounted with a single or dual woofers/subwoofer. Are you thinking of new speakers Bill?
        • 5673
        Originally posted by ThomasW
        ...Using side firing woofer/woofers and a 100Hz XO point the front baffle can be kept narrow.
        Thanks, Thomas!
          • 5673
          Well, my system has outgrown my NatP’s, and I am interested in something more resolving.
          Problem is I don’t want to increase the foot print too much, my room is too small for much more. I also wanted to avoid a sub(s) for the same reason. But I want as close to a full range tower as possible.
          My concern with side mounting a woofer or sub is that I will not have precise staging in the lower frequency range. And I would like to have the LF xo as high as possible to get the best lower-mid performance as possible from the NeoD’s. Also, I am planning to go with a curved side cabinet, side-mounting a woofer would be a nightmare.
          Yeah, I know, I want to have my cake and eat it, too.
          BTW, do you know what the NeoD LF roll-off is on a sealed version is?
            • 16073
            Well if the Neo's will play down past 100hz no problem which I doubt they would have issue with you shouldn't have any issues crossing to a woofer in the bass bin at 100hz and I believe that that frequency bass is pretty non directional? I doubt you'd be disappointed anyways.
              This needs to be done with a outboard active crossover so you can experiment with different points. At 100Hz or lower there will be minimal issues with smearing of the sound stage.
              Since these cabinets are being made from scratch having a flat spot for woofer shouldn't be that big a deal. Just start the curve further back on the side with the woofers.
              Nope I'd need to run a sim.
                • 16073
                Ah missed the part about the curved cabinet
                  • 5673
                  Can I run the sim using unibox or win freeware programs that I already have, or is a more sophisticated software required?
                    • 5204
                    Unibox will work great.
                    See post 6 to see Jon's sims using Unibox for the vented config:
                      • 5673
                      Per post 6, as you so kindly pointed out to me:
                      "To build a version more optimized for wide range music, I'd recommend a larger custom enclosure, with a net internal volume of 40 liters (gross volume around 46 liters).
                      Then, tuning to ~ 30 Hz, with a 3" ID port instead of 2", you can get extended bass response with a slight anechoic droop that should sound pretty flat in room with boundary lift..............
                      ...........If you want to go sealed, and are crossing at 80 - 100 Hz, that should be doable to, but for running full range, consider this- sealed, the maximum output at 30 Hz per cabinet is about 90 dB; the 40 liter ported version can do about 102 dB at 30 Hz."
                      Thanks for your help, Ryan!
                      Some of the info (and there is a ton of it) is burried so deep I have a hard time finding it even when doing a 'search'.
                        • 16073
                        Yeah 40L isn't huge might be silly to go sealed :B Not sure if there would be a ton more low end then the Nat's though guessing thats why you want the bass bins.
