So I’m trying to make up a decent crossover for the first time and wondering about the importance of squishing impedance peaks. I’ve got a tweeter that I measured and found a decent bump as seen here:
Zaph has been using a similar tweeter in his ZRT project linked here:
He says that this ~500 Hz peak indicates ringing and that this ringing must be avoided. His solution is to use an LCR circuit. As I understand it, that’s just a notch filter. The peak is not seen in the frequency response of the tweeter alone. So how important is avoiding that peak?
If it is important to avoid this peak an LCR filter is one option. Would an equally good option be to just roll off the tweeter such that it is not playing at that frequency?
For example, here is Zaph’s plot and it looks like he is down ~25 db where the tweeter peak comes into play. That’s far down but maybe not quite far enough. So he uses a notch filter to avoid it.
Alternatively, maybe one can just get off the tweeter well before that bump. For example, here is a preliminary crossover of mine. I’m down ~35 db before the impedance bump of the tweeter comes into play. Maybe that’s off the tweeter enough (or I could get off sooner if that would be sufficient). Is that approach OK?
Maybe 2 ways to skin a... er... make a speaker.
I know that Zobels are another issue, trying to get the baseline of the impedance plots to be flat but not dealing with the peaks. I guess it’s nice to have the baseline flat as well.
I’m just trying to learn here. Kind of like learning to park by sound, I know. Thanks for any help.
-Jon
-Jon
