So last night I was recalibrating the speaker levels on my Rotel 1066 HT pre/pro. I had my RS SPL meter in hand, and was using 75 dB as my reference level. I had just completed adjusting the individual speaker volumes when I heard what I can only describe as a V hi-pitch, low level ‘screech’ coming from the right front Natalie P tower. As soon as looked at it I saw a dull blue-ish plasma coming from behind the grill of the RS28A-4 tweeter. Then, not more that a second or two latter, the arcing stopped, I heard soft ‘Pop’, followed by a little cloud of white-ish grey smoke.
Both mid drivers are functioning normally, and I ran the speaker the rest of the night after removing the tweeter with no ill effects. The left side speaker is also performing as rock solidly as ever. As far as my electronics, everything is operating normally, and there are no issues with balance or channel separation. My Nat P’s have been performing flawlessly since the day they were made a year and a half ago. They are run nearly every day for at least 5 hours (12 or more on weekends) and have never given even a hint of any type of problem. IMHO, they made the Energizer Bunny look downright anemic.
Could a failed XO cause this type of catastrophic failure? I am hesitant to re-install the new RS28A I just ordered at cost of $57 when it gets here, for fear I may end up with two blown tweeters and still no idea of what caused it. Is it possible to verify the HF XO circuit with my Fluke V/O meter before I take a chance of needlessly wasting another speaker?
TIA Guys
TIA Guys
