I am trying to understand what the difference in sound will be between the new Zaph ZRT project vs the Modula NeoD CC.
The speakers will be ceiling mounted (near corners) in a bedroom about 15' x 15'. I have a pair of RS 180 Modula MT's in there now and they sound very good. However, they are my son's and he wants them back. I am not so concerned about the baffle step correction as I intend to equalize them with a parametric EQ and should be able to compensate for BSC or not. The existing RS 180 Modula MT's with the normal BSC sound good.
I like the RS 180 Modula MT's. I wish they could play a bit louder. I sense that they are straining at moderately high volume levels
I am specifically considering the MD20 enclosure 21L" x 9W" x 10.5D" for the ZRT vs the Modula NeoD CC in PE cabinets 22L" 9W" 13.5D". They are close in size. I am not to worried about the low end as I am comfortable with box modeling and have yet to go through the exercise (ported or not and actual box size).
What I find interesting is that the ZRT uses low distortion drivers. I am not sure what that sounds like except for the phrase "can listen to them all day - non fatiguing".
I suspect that the Modula NeoD CC will play louder as work load is split between 3 drivers vs two. Is this the case? I also suspect that the Modula NeoD CC will not be quite as "non fatiguing" as the ZRT.
I was wondering are there any sound generalities that a 3 way has vs a two way or is it really design dependent?
I am not concerned about puch or other such descriptions about the sound. I fully expect both speaks to sound fantastic. I am just trying to understand what the neiuaunaces may be between the two.
