Zaph ZDT3.5 baffle question?
  • tylerdurden
    • 95
    Does the baffle thickness have to be 3/4"? Can it be 1" with a 3/4 roundover on the edge with the drivers countersunk/flush mounted? With the inside chamfered of course. Thank you!!
    Bobby
    • 5204
    You can certainly increase the baffle thickness. I used 1.5" on my Khans. Just increase the depth the same amount so that the internal volume is the same.
    I would keep the edge roundover the same as Zaph used for most consistent results.
    • stangbat
      • 171
      FYI, the following can be found on his Design Mantras page.
      All of my designs call for roundovers on the baffle. 1/2" is the minimum, but 3/4" is better if you have a large shank, variable speed router than can handle it. The roundover is required to help smooth out the diffraction ripple response.
      • tylerdurden
        • 95
        Thank you --k--!! I figured this would be the case but I wanted to make sure. I read in Zaph's "Design Mantra's" section on his websight, that he suggests a 3/4" roundover to be the optimum, 1/2" to be minimum. I have a really good Porter-Cable 1/2" shank 3-3/4horse router, so a large roundover is no problem.
        It looks like I will have to take down a little more for the rear mount on the tweeter as well. The rear mount reguires a 12mm depth. Thanks again!
        Bobby
        Thank you Stang! I had already read that. I think I have read everything on his site. :B
