How would this stack up for Full Range project?
  • its_bacon12
    • 73
    EDIT: I am very interested on other people's opinions on these..
  • joecarrow
    • 753
    That particular driver is fairly widely recognized as having excellent quality. The overall speaker design doesn't look bad- but you have to be realistic when you're thinking about "loud". It's a single 4" driver, so if you ask it to produce any kind of bass it will be severely limited in how loud it can go.
    The overall execution is better than a lot of the old "full range" projects that folks used to swear by. At least this one has a corrective filter for baffle step, etc, but it still has the problem of directing all of the high frequency sound dead-ahead in a beam. It'd just require you to pay attention to setting it up in your room, and then sit in the "sweet spot" for good sound.
    -Joe Carrow
      • 5204
      I heard it at Iowa. It was good. The W4 is a great driver. Its a 4" driver, so don't expect full range bass.
      I think that Wolf's box is probably more complex than it needs to be. Jed has a similar design, but a more straightforward enclosure.
      • its_bacon12
        • 73
        Oh I'd definitely be incorporating a subwoofer up to about 100 Hz.. Anything above that would be the FR driver
        • its_bacon12
          • 73
          http://htguide.com/forum/showthread.php4?t=27583
          ooooh I like the R4's ALOT. I think I'm gonna do those instead.
          • MuaDibb
            • Oct 2006
            • 94
            I heard this speaker at the DIY in Lexington, right after I played my D4's. It sounded very good for a full range, but it sounds better with a tweeter.
            Ultimately all things are known because we want to believe we know.
            Zensunni Wanderer
            • dawg1161
              • 238
              I built the F4's and they sound awesome (thanks Jed) and even better with a sub.
              • Jed
                • 3621
                Thanks Gentlemen. The F4 is a nice little design (affordable), but I agree with MuaDibb that the tweeter makes a HUGE difference in sound quality. The response on a full range Lineup F4 or Wolf's design might look flat up to 20k on axis, but the dispersion is lacking and that makes the sound a bit less exciting to listen to. It's more of a sin of omission- so to speak.
                • Saurav
                  • 1166
                  I always thought the best use for a good fullrange driver was as a 'wide' midrange. Give it the help it needs at the top and bottom, and you could have a very nice speaker.
