I've built a center channel with this speaker before but I didn't build the crossover. I took a chance and just used some leftover Boston Acoustics ones from 20 years ago. The result? It actually sounded great for center channel. That center channel design used a pair of these coaxials in a ported box, tuned by my ears. I have one of these left, which I'm dedicating more airspace... about .60 cu. ft. First trying sealed for simplicity, but I may end up porting it. I'm trying to find the whitepaper specs on this woofer but I only came up with the following, from a 1997 price list:
I'm not sure how they find specs like these on a coaxial without a supplied crossover. Perhaps maybe at some point, there was one accompanying it. It seems difficult to extract the characteristics of the tweeter and woofer separately based on the above info. What should I do from here if I want to figure a parts list for the x-over? I would greatly appreciate some direction on this one.
A17WG-01
61¤2“ Coax
FS = 58Hz
Qts = .60
Vas = 15 Liters
Xmax = 3mm
Power = 60w
dB sens = 87
$55.00
