So I've built my own HT using this design, Zaph's BAMTM set-up
Also have a 12" sub, and I've got everything hooked up to an Onkyo605 Receiver.
However I'm relatively noob-ish, and I need to know what's up with my Dayton Speakers (DA175s). I've had them crossed over no lower then 80Hz, and have never truly blasted them or tested them at high levels period.
Few months ago one of the speakers started to make noise around 60-80Hz I'd guess you'd call it bottoming out. So I went and just bought another Dayton woofer and left the other one hanging around my basement. Now I've got another woofer bottoming out which forces me to manage my bass precariously and the crossover settings.
How can I determine if this bottoming out of the speakers is being caused by my hand or if the woofers are just defective? Should I just contact Dayton and see if they will replace them?
Also- I recall someone mentioning the compatibility of the Onkyo to the Dayton woofers when I was deciding to build this DIY project. I wanted to build the stuff so bad that I never really put much time into finding the best match for the set-up.
So maybe someone could help me figure if the receiver is good for the set-up?
