I've looked around and can't find an answer that I understand. Hopefully some kind soul can break it down for me.
I took some measurements of well known manufactured speakers and compared them to some I designed. The measurements were done at the same time under same conditions. They are useless below 500hz but I do not believe that has any importance in this exercise. The measured phase data was stripped off and re-calculated before appropriate amount of delay was modeled back in. This was worked out by taking measuremeants of each driver without any crossover and comparing to a measurement of both drivers connected. Delay was added to the midrange until the summed response matched the measured response of both drivers.
First up is a direct on-axis test of the tweeter. Shown is the mid/tweeter curves and their summation.
..And here is a shot of the phase data.
Notice how the phase wraps around at almost the exact crossover point between the mid and tweeter.
Now here is a shot of my design and phase data, same test conditions.
Mine clearly do not wrap the phase at the xo point of 2300hz. Question is - what does that translate into for sound or is it not important? The mid and tweeter of my design do have reasonably close phase response at the crossover point which I thought was the important part.
At any rate, hats off to the guy who designed the commercial speaker I tested. Getting the drivers to follow near perfect slopes while maintaining the phase response must not have been easy.
