Best DIY speaker cabinet
  • jkrueger
    • 78
    So in this months Stereophile, in an interview with the guy from Magico, they spend some time discussing cabinets. He builds his out of extruded aluminum, and they weigh hundreds of pounds. His view on MDF is that it is not rigid enough, doesn't make a great launching point for sound waves, allows driver bolts to loosen over time, and must be the worst material for building speaker cabinets. If a person were stuck with wood as a construction material, what do you think would represent a construction technique that represented the "ultimate" wooden cabinet?
  • looneybomber
    • 194
    Ultimate? That's beyond me to know what the very best is, but a combo of plywood, MDF, sound deadener, and anything else that adds mass would be better than any single material.
    • Operandi
      • 145
      The "worst material"???
      I would say that statement right there eliminates whatever little creditability he had. :roll:.
      • Jed
        • 3621
        How else can he sell his overpriced aluminum enclosures? People will do whatever it takes to market a product even if it is based on myths. The thing is, those baseless statements eventually catch up with you after people/consumers do their research and then later realize how much BS there is in the hifi world. It definitely doesn't help the ethical companies out there.
        • Deward Hastings
          • 170
          I don't want my *enclosures* to be a "launching point" for sound waves . . . period.
          The "best" wood (wood only) enclosure would have to be curved gluelam (translam), with plenty of internal bracing. We've seen some very nice examples of that right here. Second would be more conventional box construction but with more than the usual internal bracing (to prevent panel resonances).
          Screws can pull out of MDF, or loosen, eventually, maybe. Compressable gasket reduces the chance, or the importance, of any loosening. Hurricane nuts all but eliminate it.
          • Bastek
            • Apr 2008
            • 41
            The screws in my 12yo IRS Sigmas are very tight. I have to check back in the next decade. :roll:
            • JKoravos
              • Jan 2007
              • 3
              Machined aluminum is extremely useful for many, many things, but that guy's speaker cabinets are a waste of it.
              • jkrueger
                • 78
                Best DIY speaker Cabinet
                So....even if this guy is full of crap, (I am currently enjoying my all MDF DIY speakers right now) would some laminated comination of BB ply and MDF make for a more inert cabinet? Should my next project be laminations of 1/2 inch BB play and 1/2 inch MDF to a 2 inch thickness? Would I notice a difference?
                  • 16073
                  Kind of funny he says that as a lot of his speakers use wood. I don't doubt that his aluminum cabinets might be awesome but for the weight and price and everything else I don't think they are going to be all that much better then a nice translam or something.
                  • Rolex
                    • 386
                    You guys do realize this is Magico, the company with the Mini that uses the stacked lamination curved enclosure, right? The people that have made those here, copied Magicos design.
                    His complaint isn't with wood. His enclosures are not 100% aluminum. His complaint is with MDF. Put a screw into mdf, then put a screw into baltic birch (his material of choice with aluminum) and see which one you can strip out easier. Even if you use a T nut or a hurricane nut or whatever, you still have an easier time tearing out the mdf.
                    I would be careful making claims like this:
                    "but a combo of plywood, MDF, sound deadener, and anything else that adds mass would be better than any single material."
                    that may not necessarily be true.
                    • 69Stingray
                      • Feb 2007
                      • 100
                      The ideal cabinet is one that does not resonant at any given frequency inside the operational range. I assume the aluminum cabinet pushes the resonant frequency high enough in the frequency range such that the acoustic power of the drivers does not excite it.
                      If a cabinet has a resonant frequency inside the desired operational range, then it would be nice to dampen it's response. This is way MDF is popular (besides cost), it is more damp then stiffer materials. Think metal cones vs. paper cones.
                      Composite structures are also popular (say plywood + MDF) because you can combine stiffness (plywood) with damping (MDF).
                      • looneybomber
                        • 194
                        Oops. I was meaning any single material I mentioned. Combo's are always good because each material will have it's own resonance, which can be damped by the other material.
                        • JonP
                          • 692
                          It gets to be a complicated question with complicated answers...
                          I did a lot of reading and netsearching on the subject. There's some good and interesting info and experiments out there to find.
                          What seems to be the deal with making composite layers or constrained layer boxes, is that there's a certain ratio of best result... you can have too much or too little of a different material with lesser results. So, different sizes of panels in a box would need different ratios. And, it also depends on how thick, how flexable, how lossy, the various layers are. So, to do it really well, you probably need to measure how it's working.
                          But overall, at a basic level, it's not too picky.. a stiffer layer with a lossy layer behind it will be damped more. Thicker is stiffer. Brace your panels well, smaller vibrating areas radiate less sound, etc... Good construction practices will get you a large percentage of possible result.
                          • 1Michael
                            • 293
                            Using an inner core of 3/4 MDF and 3/4 Ply on the outside makes for a very well damped box. It is my prefered method. Wood screws should only be used to hold the box together while the glue dries so who cares if it strips
                            Michael
                            Chesapeake Va.
                            • Rolex
                              • 386
                              This is not the issue with screws stripping. It is where the driver is mounted to that cabinet that this becomes an issue. Even threaded inserts can strip easliy in mdf. Not so with baltic birch. Meaning, not nearly as easy. Can still happen though.
                              • knifeinthesink
                                • 163
                                jk,
                                you might find this interesting if you haven't already seen it.
                                its not in English but online translators are sufficient to get the material names that aren't obvious.
                                • Curt C
                                  • 791
                                  I can live with the cast aluminum front baffles, and think the issue of screws loosening up in MDF is just due to poor execution.
                                  But what I wonder is: In a high end design such as this, why wen't the woofers anchored to by baffle by the magnet assembly. The pic in the article show the driver mounted with small brackets over the edge of the driver flanges. Surely the drivers would get a better 'launch' if physically tied to the baffle by their center of mass (the magnet assy) rather than the flange. Since these are custom castings anyway, I would think it would have been relatively easy to cast in the necessary attachment flanges.
                                  Curt's Speaker Design Works
                                  • jkrueger
                                    • 78
                                    Thanks for the replys. I have tightened my own screws once since completing my last build, and they mostly needed half a turn. It seemed that the mid screws needed the most attention. I can hardly believe that they will eventually pull out or become a problem though. My current cabinets are 100% MDF. I think that next time I build something important for myself, I will use some sort of multi material lamentation.
                                    • Deward Hastings
                                      • 170
                                      Originally posted by Curt C
                                      But what I wonder is: In a high end design such as this, why wen't the woofers anchored to by baffle by the magnet assembly. C
                                      Yup.
                                      • Deward Hastings
                                        • 170
                                        Should have linked this, too . . .
