Tang Band 25-1414SC Ti neo Tweeter
  • Habs4life
    • 85
    Does any one have expierience with this unit?I snagged one of these from PE as they were on clearance for only $14.My plan is to use it in a 3 way center channel.Looking at Zaphs measurements however it appears there is a nasty peak in the 17-22k region.This break up mode seems to be lower in frequency and wider in bandwidth than normally seen on metal domes such as the SEAS units.
    My question is should I try to kill this peak with a notch filter or will its existance be relatively inaudible? Any input is appreciated.
    • 16073
    There was a thread posted about this one (I believe it was) just a week or so ago.
    • Habs4life
      • 85
      Oh OK thanks. I did' nt see that thread but I will search for it.
      • fjhuerta
        • 1140
        Nope, that tweeter was the expensive inverted dome tweeter. The 1414SC hasn't been discussed much, since at its original price a Vifa D26 made a lot more sense. Check out Zaph's page.
        Javier Huerta
        • jkrutke
          • 590
          Personally, I wouldn't worry about the peak, it will barely be audible even for young ears.
          For those that don't currently own a Tangband 25-1414, Madisound's new Vifa DQ25SC05 titanium dome is better. Very clean on the low end. I like it. Results for those will be posted on Sunday along with some other stuff.
          Zaph|Audio
          • Habs4life
            • 85
            Thanks for the reply John,I will leave the peak alone then and see how it sounds.The Vifa DQ25 sure looks to be a better choice though Im hoping to actively crossover with an LR4 in 2.2k range but with the higher Fs I suspect it might prefer to be crossed abit higher than the 1414?
