bass is louder when the statements out of phase but!
  • Coconutout
    • Oct 2006
    • 329
    hey guys i was doing some test tones out of boredom on my statements and noticed that the bass is louder/deeper when the speakers are out of phase. or should i say when bass in phase and mids/tweet out of phase? the imaging gets 'spacy' and dispersed at the same time. so i said this must be because i wired the woofers wrong when i reconditioned the drivers. so i reversed mids and tweet on right side while that unit was still wired 'out of phase'. i didn't want to open up the woofers just because w4 and neo are smaller/lighter to work with. anyways, now it sounds like mids and tweet are even MORE out of phase and the imaging is all slanted to the right. this is baffling. where is the problem? (besides my inadequacy at DIY)
    could it be because of how my amp works? i remember reading something about NAD 2200 having inverted bass. maybe my sherwood am 7040 is same deal? no spec to be found whatsoever for this amp tho...
    Follow the wiring diagram, the amp has nothing to do with this....
    • Coconutout
      • Oct 2006
      • 329
      yes, the crossover should be wired correctly. i built them last fall and it was correct back then. i checked them rigorously when i built them. however the drivers were replaced just two weeks ago.
        I think you missed my point....
        • Coconutout
          • Oct 2006
          • 329
          sorry. thomas. i did go ahead and check everything just now. in order to do that i had to take out the woofer which i was dreading in first place. everything looked to be in order. however i did see that the woofers were wired backwards. :P. so what you told me to do solved the problem in the end . thank you
          • Curt C
            • 791
            I'm glad you found the solution to your issue. To answer your question above, I'll make this "Statement": :B
            "Phase is relative."
            That is, the actual phase is immaterial as long as the phase relationships between the components are maintained. It matters naught whether your amp (or speaker, or other component) retains absolute polarity or if it inverts it. As long as everybody is inverted, (or not) all is well. In crossover design, only convention dictates the woofers will always be connected in phase. There is no other legitimate reason to do so. To assume that absolute polarity was maintained from the original recording mic, through the recording/mixing/engineering/mastering/production/reproduction chain is almost assuredly wishful thinking.
            Curt's Speaker Design Works
              • 3814
              The way the schematic reads it's easy to get the mid's +/- mixed up. I did that when I built the center. No big deal though it's easy to fix.
              -Chuck
