Well I will be picking up a new soundcard for making measurements with, and I just felt the need to pick up some drivers to test. No idea how this will go, since it is only my 2nd design. This time I'm going to try to do a simple 2-way. I also haven't seen anyone use the Dayton DC25TS-8 yet, so I figured I'd give it a go. I then ordered a couple of buyout 6" shielded cast frame woofers. Part Number 299-818. My wife is absolutely going to punish me for this, since I am *supposed* to be getting our house ready to sell. I'll fit it all in somewhere. I will tell her they are a present for some of our friends we are going to leave....
I have a pile of XO parts in a box from working on my previous design, I will attempt to use parts from there only. The DC28F-8 would match from a sensitivity standpoint (at least from published specs) but that has been widely used, and if nothing else getting some data on the DC25 will be interesting.
BOM so far: Prices Each
2 Dayton DC25TS-8 (shielded) 275-055 $10.00 x2 = 20.00
2 Buyout 6" Cast Woofer (shielded) 299-818 $17.63 x2 = 35.26
2 Dayton 5.5uF Poly Caps 027-425 $2.27 x2 = 4.54
2 Dayton 1.0uF Poly Caps 027-410 $1.06 x2 = 2.12
2 Dayton 10uF Poly Caps 027-428 $3.75 x2 = 7.50
2 Jantzen .55mH 20g Inductor 255-038 $4.32 x2 = 8.64
2 Jantzen .85mH 18g Inductor 255-244 $6.95 x2 = 13.90
2 Dayton 10 Ohm Resistor 004-10 $1.25 x2 = 2.50
Total = $94.46 + shipping
Crossover Schematic. Just a note, this is not the "ideal" crossover, it was modified to deal with the leftover parts I had.
And this is the simulated response, along with what was actually measured. Blue is simulated, Red is measured (gated at 1m) Note I removed the Lpad I thought I needed.
Estimated Delivery for Friday. I should have a good weekend
