Well, besides being physically huge, that is...
Consider a WMTMW with RS270 drivers as W's, vs. a WWMTMWW with RS225's as woofers.
Interior volume should be roughly the same - 200L.
Output levels would be very close, but impedance (with the 8 Ohm models) would be about 8 Ohm for the RS225's, vs. 4 Ohm for the 270s.
The thing I'm not so sure about is - vertical dispersion.
If I had a WWMTMWW would I need to roll off the outer woofers if I'm planning to use a 250 Hz crossover to the M's?
The reason I'm thinking about 4 RS225's per side is price. Buying 4 270's costs about $440 with s/H to Mexico. I already have 2 225's, so 4 extra 225's are $280 USD.
What do you think?
What do you think?
