1" roundover
  • megamuel
    • 56
    1" roundover
    Could someone please show me a bit on this website:
    Trend are the leading brand of Routers, Cutters, Jigs & Accessories, Power Tool Accessories, Safety/PPE, Tool Storage, Abrasives & CNC Machines sold through a network of stockists in the United Kingdom, Ireland, USA & Canada. Our products are also available online form e-commerce partners in Europe, New Zealand, Australia and many more worldwide
    or this one:
    Infinity Tools is a worldwide distributor of high quality router bits and other wood cutting tools for the professional as well as the weekend woodworker.
    ....that will give me a 1" roundover?! I know this seems like a stupid question but I am very confused!!! I'll be using my Dad's Trend t4 router which has 1/4" shank. Thanks!
    Sam.
  • mpotoka
    • 203
    You probably won't be able to get a 1" roundover without a 1/2" shank
      Nobody (I think) makes a roundover bit bigger than 1/2" with a 1/4" shank. You need a beefy router with a 1/2" collet to do a 1" roundover. The bit will be 2 1/2" in diameter and very heavy. A 1/4" shank would most likely break, sending a big chunk of 20,000 RPM steel flying your direction... definitely hazardous to your health.
      • megamuel
        • 56
        Ahh I see, I didn't realise... Thats the nice big roundover out of the question then!
        • JonP
          • 692
          They are available up to 1.5"... pricey, and need that 1/2" collet, of course.
          Probably need over 2hp, and with any large bit, need to have speed control to slow down the router to a safe speed. You DON'T want to run something like that at 24,000 rpm! Even my 3/4" roundover is reccomended to be run down around 12,000-14,000.
            • 5204
            Even the cheapest routers over here come with 1/2" collets these days. Maybe it is time to upgrade your router?
            • Bent
              • Sep 2003
              • 1570
              my P.O.S. Skill router with the "auto eccentric hole option" has a 1/2 inch collet with a 1/4" collet insert
              • megamuel
                • 56
                My Dad only just bought it, just reading up on it now and it says its a light duty router so that would explain it. I don't have a clue about routers (obviously)! I'll have to see if I can borrow one! Thanks for the quick answers guys
                  Why mess with puny 1" roundovers? Check out these ready made 2" to 4" quarter rounds http://www.aitwood.com/StoreFront.As...arter%20Rounds
                    • 5204
                    Bob makes a good point. You can leave a notch in the corner, then fill it with quarter round.
                    • relder
                      • 25
                      A 1/2" collet isn't a guarantee you can swing a bit that big either. My dewalt plunge can't (I learn after I buy the bit) the diameter of hole in the base isn't that big. So measure before you buy.
                        • 5204
                        Ahhhh, the hole in the plastic baseplate isn't a limiting factor. Remove the baseplate and make a new larger baseplate out of MDF or lexan. I had to do this also with my Hitachi. It worked well. I made my new baseplate about 12" long and put a handle on to make it easier to work with and more stable on the work piece. It was ugly, but took about ten minutes to put together.
                          • 5204
                          Photos of my baseplate, and ironicly a 1" bit.
                          • relder
                            • 25
                            It is if it's aluminum and integral to the router. See picture: Amazon link
                            YMMV
                            • Brian Bunge
                              • Nov 2001
                              • 1389
                              I love my DW621 (now that my uncle referbished it for me) but yeah, you aren't going to get a big bit like that in there. That's why I have a Porter Cable router that sits in the router table!
                                • 16073
                                I have a Hitachi MKV12 (I think this is the model) and it does 1/4" and 1/2" Shank...it's a beast
                                • Brian Bunge
                                  • Nov 2001
                                  • 1389
                                  Oh, mine has both 1/4" and 1/2" collets, it's just that a bit with that kind of diameter isn't going to fit in this particular DeWalt. It will easily fit in the DW618 that I have or the Porter Cable.
                                  • JoshK
                                    • 748
                                    I have a 1.25" roundover bit. Its huge. Its intimidating, its a beast. I plan to use it with my table saw router table insert. I don't want to hand hold the router when using this bit. Something else to consider.
                                      • 5204
                                      yeah, ymmv with different routers.
                                      Josh, you sissy! I did a 1 1/4" roundover with a hand-held. I swore afterwards I would never do it again, but I did it. :P
                                        There's a reason that "smaller" e.g 2 HP routers have smaller holes in the baseplate. That 3" diameter 1.25" roundover bit is spinning a bunch of mass and a smaller router has smaller bearings and internal shaft. I got a lot of vibration and a rough cut with a 2HP Bosch router (very good within its limits) that I slowed down with my variac. I thought it was the cheap bit until I put it in my Hitachi MV12.
                                        The Hitachi MV12 will swing a 3.25-3.5" bit with a standard baseplate. Yep, Dougie, it is a beast and I love it!
                                        BTW, I always keep the cabinet between me and a big bit. It probably wouldn't stop it if it comes apart, but at least it will slow it down a bit.
