What value Inductor for simple lowpass @ 100hz ?
  • IllNastyImpreza
    • 77
    I've got some bass shakers, 4 OHMs. frequency responce of 20-100hz
    What value Inductor can I use to make a simple lowpass at 100 hz ??
    should I go with 100 or maybee little lower due to the narrow slope ??
    This is an situation where passive line level components are a good choice...if you don't want to build your own buy F-Mods, otherwise go here....
      6.4 mH will give you a 6dB lowpass at 100 Hz. Or you could stick an F-mod between the preamp and amp for a 12dB lowpass. It's not like you need an exact crossover with a bass shaker.
      Edit: Thomas beat me to it with the F-mod.
        Some of us old geezers are surprisingly fast.... :B
        • servicetech
          • 209
          I won't bother with a passive crossover for bass shakers, let the natural impedance rise of the voice coil control the cutoff.
          • IllNastyImpreza
            • 77
            are you telling me to give them full range of signal ???
            awesome... thanks guys
            does it matter much which type of coil I get? whats the cheapest ?
            • servicetech
              • 209
              The bass shaker is 8 ohms only at certain frequencies. As frequency rises so does driver impedance creating a natural "cut off". No passive crossover is needed. If the bass shakers are being driven by a separate amp by all means use a crossover at the line level such as an F-mod.
