Im rather new to the DIY speaker world. I have buildt an 2-way floorstander from scratch, and learned a lot
But there is a few things about phase that confuses me, and I hope some of you could learn me som more.
I have worked with an xo that is 1.order plus zobel on the woofer and 2.order plus L-pad on the tweeter.
I can adjust the values to 2. order acoustic slopes, and get a good reverse null, measured at 1 metre.
What happens at 2, 3 and 4 metres? Are the phase still correct?
If I use a 1.order plus zobel at both low and highpass, should I still aming for a good reverse null?
A theoretical 1.order network should be 90 degr out of phase, right?
How can I check that my xo is correct then?
I have some more questions but hopefully someone could answer this first.
Thanks!
Thanks!
