I am tuning my design and I was wondering what the numbers in the top right corner mean? I am referring to the Hz, and dB number boxes...I have an idea but I want to be sure so I don't mess anything up. Also is there anything in particular I should look for in regards of those two numbers? Thanks a lot guys, oh and if I listen to music and movies at like say 40/60 where should I try to tune it to, I have it at ~22.5Hz? Sorry for the noob questions, and once again TY.
Simple WinIsd Alpha question!
Tags: None
Haha TY sorry I am super new and didn't know that you needed all that info for you to help. I am more than happy to fill you in though...my room is about 15x20, and is filled in nicely. Yes I am pairing the Dayton RSS315 4ohm 12", and the Dayton 240w plate amp. My internal enclosure is about 3.35cu.ft. after taking all displacement accounted for. My design is a 4"x16" port and a 22.5hz tune lol, I have seen HT subs at like 15-20hz and I would like music as well... so 22hz seemed good but not sure.- Bottom
Without having modeled it, that should be OK if it produces a slight (1-3 dB) droop in response to counter room gain. You might want t consider a high pass filter, say second order at 15 Hz or so, to protect the sub from the super low effects in some movies.- Bottom
Originally posted by BobEllisYou might want t consider a high pass filter, say second order at 15 Hz or so, to protect the sub from the super low effects in some movies.- Bottom
I read in a review PDF by Darren Kuzma that the Dayton amp is 3dB down to 18hz on the low side as well, and goes as high as 168hz on the high side. I will be buying the MDF Thursday or Friday and get to work on Saturday and Sunday.- Bottom
