I just bought a pair of the Peerless 831882 Exclusive woofers to make some small book shelve speakers with. Does anyone have project plans for these woofers with a nice tweeter? I figured I'd try to ask before I contract Madisound to create some custom crossovers.
Anyone have project plans utilizing the Peerless 831882 (5.25") Exclusive Driver?
Originally posted by Jonasz- Bottom
The plans are links (aka thumbnails)
Originally posted by omarmipiunfortunately I cannot read the language on that site.
Just go to:http://www.google.com/translate_t
and you get this: http://www.google.com/translate?u=ht...&hl=en&ie=UTF8- Bottom
The port output at 800Hz is almost as high as the primary port output between 50 and 90Hz. Presumably the driver's rear radiation couples too efficiently to the slot port resonance and contributes to some 2 - 3 dB excess output at 800Hz as seen on the ATB Precision plot.
Perhaps try a cylindrical port mounted high eg behind the tweeter.- Bottom
Originally posted by davey_mThe port output at 800Hz is almost as high as the primary port output between 50 and 90Hz. Presumably the driver's rear radiation couples too efficiently to the slot port resonance and contributes to some 2 - 3 dB excess output at 800Hz as seen on the ATB Precision plot.
Originally posted by bobhowell??? Don't follow!
You see the usual woofer roll off, with the port contribution slightly below it. However the port also appears to have high output around 800hz.
Whether or not this has been commented on in the design I don't know.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
Now with website. www.5een.co.uk Still under construction.- Bottom
Looks like the design favours nearfield (eg. computer / desk) listening or for close wall mounting. Does not look like enough baffle step compensation applied - loose translation, the speaker will sound "thin" and bass-less if you use it in a conventional (on stands in the room away from the rear wall) manner.- Bottom
I got it. I am planning to run it sealed with sub. But I will have to think about BSC. I think I will want that. He has comments about the design but Google Thanslate conceals the meaning. Hence my caution. Seems he recomends/offers version to cut output abound 4000hz. I don't know if there is more.
In 7 L, roll off is gradual and I could xo to sub at 80-120 as needed.
Thanks for the help
Bob- Bottom
Originally posted by bobhowellI got it. I am planning to run it sealed with sub. But I will have to think about BSC. I think I will want that. He has comments about the design but Google Thanslate conceals the meaning. Hence my caution. Seems he recomends/offers version to cut output abound 4000hz. I don't know if there is more.
Thanks for the help
Bob
Without changing the crossover, all you can do is place the speakers hard against the wall and block the port / build as a sealed design.- Bottom
Originally posted by Dave BulletLooks like the design favours nearfield (eg. computer / desk) listening or for close wall mounting. Does not look like enough baffle step compensation applied - loose translation, the speaker will sound "thin" and bass-less if you use it in a conventional (on stands in the room away from the rear wall) manner.
Clairify please,
Bob- Bottom
As davey_m said. A nearfield measurement (one where the microphone is placed close enough to the driver that the baffle effect is swamped by the driver's "natural" response) is only useful for low frequency response measurements, or where you do NOT want the effect of the baffle to factor.
The other tipoff is the low value series inductor for the woofer. Unless the driver has baffle step "designed" into it (most don't) then the inductor is usually around 2mH (or greater) to indicate some level of baffle step compensation. The other option is a lower value inductor, but a parallel resistor to "shave" a few dB off above where the inductor resistance exceeds the parallel resistor. The one in the design above is only 0.68mH- Bottom
Thanks. Now I see. One thought is to put it in a sealed, 3-4L box, which gives a Q of .700 or so, and power handling of about 30 watts. My subs are one of the NHT buyout amps with a spectrial tilt, driving two, 10"woofers in seperate cabinets spaced 8" apart and another sub available to help, if needed, to even out room modes. Can I use these adjustments to level out the responce? I will be experimenting with REW.
Thanks for the help,
Bob- Bottom
