I have a feeling by the end of this post some of you might be cringing, but here is what I've come up with for a home theater DIY setup.
I purchased a Onkyo 805 and decided to try to build a home theater setup that is within a interesting budget. My current plan is to build two dipole cabinets with the RS150S-8 drivers, a center with two RS150S-8 drivers and two RS180S-8, two mains with two RS180-S, one RS150S-8 and one D26NC55 tweeter, and a sub cabinet with two 15" subs powered by a seperate amp.
I wanted to do all of them in sealed enclosures and built a test cabinet already with two RS180-S drivers that I have. I have been able to cut out enough of the high end with the equalizer / channel on the receiver and the active high pass to make the dipoles and center sound passable (I'm not getting any noticeable highs crashing, at least for anyone other than a audiophile).
If that didn't make you cringe, this will. I wanted to run the Mains with just a high pass on the tweeters and the 50Hz high pass on the receiver. I'll admit it's not an ideal setup, but I'm just lacking the budget to do the full 2-way passive crossover.
I'm sure this setup would sound better with some of the proven crossovers designed here and I'm fine with loosing a little bit of clarity that I might have gotten at the expense of a proper crossover setup, but my main concern is that the setup may sound completely horrible. My tests with the 7" Daytons using the builtin equalizer and high pass in the receiver has sounded surprisingly good to me. I guess the question is, would the Mains sound good with just the high pass on the tweeter and the mids left alone?
I know the strongly suggested path is to do one of the designs listed here, but I'm seriously not able to add the ~$250 / speaker in crossover parts for this setup, no matter how much I want to.
Thank you for your time and patience with a newbie
