New to using a router to cut speaker holes and I have few questions for anyone that cares to answer them. When routing the speaker cut outs should the speaker flange diameter be cut first (appropriate depth of course) then remove the material to the second cut out for the speaker hole itself? Also when cutting the hole is the 1/3 rule (cut the material in thirds depthwise till complete) still a good guide? I'm working on a set of Modula MT's and will be cutting the front baffles this weekend.
Router questions
Originally posted by DPA101New to using a router to cut speaker holes and I have few questions for anyone that cares to answer them. When routing the speaker cut outs should the speaker flange diameter be cut first (appropriate depth of course) then remove the material to the second cut out for the speaker hole itself? Also when cutting the hole is the 1/3 rule (cut the material in thirds depthwise till complete) still a good guide? I'm working on a set of Modula MT's and will be cutting the front baffles this weekend.
You are correct on everything you said. Id recommend getting a scrap piece of MDF and practicing on that first, then do it on the real baffel. Best of luck :T- Bottom
Originally posted by subynubeYou are correct on everything you said. Id recommend getting a scrap piece of MDF and practicing on that first, then do it on the real baffel. Best of luck :TDave- Bottom
Also, screwing down the center piece that you're cutting out helps to get a clean cutout (I didn't on the first one or two holes and you don't quite finish the cut cleanly, either leaving a little ridge or cutting into the baffle as the piece you're cutting out becomes loose).- Bottom
I never use the one third rule, never heard of it. I do use a good bit with a plung type router and never go deeper than a 1/4" per cut. A lot has to do with the router your'e using and what capacity it can handle. Often I'll use a 3/4" or 1/2" bit for the outter diameter. Work my way in and change to a 1/4" down ward spiral cutting bit.
What are you using for a router guide?- Bottom
Originally posted by DrysealsI never use the one third rule, never heard of it. I do use a good bit with a plung type router and never go deeper than a 1/4" per cut. A lot has to do with the router your'e using and what capacity it can handle. Often I'll use a 3/4" or 1/2" bit for the outter diameter. Work my way in and change to a 1/4" down ward spiral cutting bit.
What are you using for a router guide?Dave- Bottom
Originally posted by DrysealsWork my way in and change to a 1/4" down ward spiral cutting bit.
FWIW there is no 1/3rd rule. That would make sense if all wood were 1/2" thick, but it would be silly if the wood is 2" thick, or considering the differences between hard and soft woods....
Originally posted by ThomasWMost use an up-cut spiral twist bit, that removes the sawdust from the hole. Down-cuts are primarily used when the wood has already been veneered.
I have an upward spiral cutting bit that I've haven't tried out yet for holes, old habits die hard. Might give it a whirl tonight.
I have a dust collection system for the larger tools but none for the smaller ones, hand tools. Last year I took a rather large squirrel cage fan and made a air purifier setup on wheels. The nice thing about it is it works great for blowing the dust away from me. Just gets all over the cars.- Bottom
Originally posted by DPA101I'm using the Jasper 200 circle jig and it works great.- Bottom
Yep, I need one of those spiral bits as my 1/4" straight bit is not long enough to go through the entire front baffle. Had to turn it over and finish it from the other side. Worked well though and my Modulas will be done tonight. Just need to finish a bit on the crossovers and apply to the other speaker cabinet damping.Dave- Bottom
Originally posted by DPA101Yep, I need one of those spiral bits as my 1/4" straight bit is not long enough to go through the entire front baffle. Had to turn it over and finish it from the other side. Worked well though and my Modulas will be done tonight. Just need to finish a bit on the crossovers and apply to the other speaker cabinet damping.- Bottom
Also try MLCS; they are sort of a co-op and have excellent prices. Every bit I have reseived has been the equivelent of CMT, Whiteside, Freud ets. The Katana series is their top of the line.
Has anyone tried a 1/4" sleeve adapter with a 1/2" collet to avoid changing to a 1/4" collet and resetting the Jasper Jig when switching to 1/4" bits?
I was cutting a rebate with my Dewalt 621 on Sunday using a 1/2" bit and noticed an increased amount of vibration. I stopped to check and the collet had loosened and allowed the bit to slip down and cut too deeply. I know the collet was tight when I started...do you think the collet is worn and needs to be replaced? Does this occur?
RayWine is constant proof that God loves us, and loves to see us happy.
BENJAMIN FRANKLIN- Bottom
Originally posted by Ray CollinsAlso try MLCS; they are sort of a co-op and have excellent prices. Every bit I have reseived has been the equivelent of CMT, Whiteside, Freud ets. The Katana series is their top of the line.
Ray- Bottom
Dryseals,
Are you refering to the 1/4" sleeve adapter I asked about?
Originally posted by Ray CollinsI was cutting a rebate with my Dewalt 621 on Sunday using a 1/2" bit and noticed an increased amount of vibration. I stopped to check and the collet had loosened and allowed the bit to slip down and cut too deeply. I know the collet was tight when I started...do you think the collet is worn and needs to be replaced? Does this occur?
Ray
Brian Walter- Bottom
Good information Brian--thanks. If an error is possible I can commit it.
Do you have any experience with the sleeve I was refering to? It would make swapping between 1/4" and 1/2" bits a lot simpler.
There's something a bit weird regarding the 621 collets. I've had more trouble with them than any other router brand I've used. On one the sleeve that tightens the bit simply split in half.
Occasionally using the 621 with larger diameter bits they'll 'grab' and be pulled down from the collet. This is regardless of how tight the collet is, and appears to be a function of setting the bit to take too deep a 'bite'. I've had this happen with my MV12 but less often
I use 1/4"-1/2" adapters all the time. They're handy for extending the reach of shorter 1/4" bits.
Thanks for the reply Thomas; sounds like what I experienced.
Thomas,
I've had the same thing happen to me from time to time. It's usually been when I've used the router with that particular bit in it cutting a lot of holes in a short period of time. Basically I guess you could say I was "in the groove".- Bottom
