Just noticed this tweeter on Madisound in the new products. Was wondering if this is a new tweeter from Seas or if it is just new to Madisound? Curious if anybody knew anything about it. I like the looks of it from a visual standpoint.
Seas Tweeter tbcd/gb-dxt
Tags: None- Bottom
I remember Zaph posting about this fella months ago but it wasn't out at the time. All we had was a .pdf from Seas to go by. I'd be curious to see how the distortion on this pans out when a crossover is implemented due to the increased output below 10 khz.- Bottom
Cool. I'm gonna order some now. Should be an awesome tweeter with great power response and dispersion characteristics. :T
Been waiting for this one for awhile. An interesting collaboration effort from DXT and SEAS.
JedLast edited by Jed; 12 February 2008, 22:39 Tuesday.- Bottom
Hmmm the faceplate is no bigger than a regular tweeter, how effective can the WG be? I thought there was a bigger version that Zaph was more interested in?- Bottom
Originally posted by augerproHmmm the faceplate is no bigger than a regular tweeter, how effective can the WG be? I thought there was a bigger version that Zaph was more interested in?
Looking at the spec sheet it doesn't look like they achieve a constant directivity until around 4k-5k... not exactly what most people around here are looking for. I think to push the constant directivity down to the range where most people in this forum are crossing over would require a much larger WG.
Maybe I am missing something though. There isn't really that much off-axis info presented by the spec sheet.
-Chad- Bottom
yeah i wonder about that too auger
loading seems huge still according to the datasheet for such a small waveguide, still interresting for small systems
but i despise the fact that the other version simply disappeared
maybe we could ask seas about that ?
also the sharp diffraction edges, patented to the dxt technology makes me wonder. It's supposed to be calculated so it matches hi freq dispersion with mid band dispersion. I just wonder if it's real or just marketing BS. THe measurements on dxt site looks good though
A few people measured these tweeters in Europe and it was stated to have a very flat off axis response and excellent power response characteristics after implemented in a simple system. This tweeter is going to be great because you can cross a bit lower than usual with the standard tweeter and still lower distortion because of the boosted low end. Yeah it might not compete with a larger waveguide, but it definitely has some advantages and the dxt technology is very real if the published specs are believed. Most of the time Seas is pretty accurate with that so rest assured.
I'll know more Monday when my pair arrives.- Bottom
exactly what i was thinking about this small thing. Even then it would have been nice to have the larger version too.
although i fear it's just never gonna be released. It's easy to see how it's not as viable commercially as the smaller alternative.- Bottom
Originally posted by Nemophyleexactly what i was thinking about this small thing. Even then it would have been nice to have the larger version too.
Personally, waveguides of any size have value. Even the 1/2" rear mounting method I did for the D26NC55 has performance benefits over the normal flange model. Anyway, I have the DXT here and I'll likely take a look at it this weekend.- Bottom
Maybe email Peerless India and ask them if they have a dealer in the US? I think Danny Richie OEMs some of his drivers from them but I don't know if he can get the retail stuff in small quantities.
info@peerlessaudio.com
info@gr-research.comLast edited by Dennis H; 18 February 2008, 23:24 Monday.- Bottom
Just finished my testing of the DXT, not too bad. Jed, we can compare results and maybe get some more consistency data. (see the impedance plots in my blog) Check out the off axis plots and filtered HD plots.
I've been toying around with swapping the 27 and 29 series motors with no real benefit shown so far, but I have a feeling I might like the DXT better with the 27 series motor. I'll give it a try. Of course, for those who might like how that turns out, it becomes an $80 tweeter since you have to buy a 27 series to get the motor. Still worth it, IMHO.- Bottom
Originally posted by augerproAnyone know how to get a hold of these?
http://www.peerlessaudio.com/newpdfs...0waveguide.pdf- Bottom
Just checking out Zaph's tests a little. I am impressed with the off axis response. That's pretty amazing at 30 degrees off it still has changed very little. Seems to me that it will definitely have some uses.
Is this the same technology or idea that the newer morel tweeters are using too?
Morels "IDR" and seas "DXT" look different, and even without the $190 per pair price difference the seas looks more interesting to me. I am waiting patiently for those more knowledgeable than I to discuss possible applications of the tbcd/gb-dxt.- Bottom
Its a step in the right direction. Your not going to see constant directivity to our typical dome tweeter crossover points unless they get much bigger, I don't see any way around that. The advantage of this is it fits in a standard tweeter cut-out. Companies can change designs slightly, and have the marketing mojo of CD.
That large break-up out of bandwidth is a mountain! Maybe they should have used a stiffer metal dome or ceramic and pushed it up a little further.
Their marketing graphs (DXT) are just that.... I'd ignore them. They don't look like real data.
What I'd like to see is some comparisons with compression drivers & CD horns. Zaph?- Bottom
Originally posted by mlwMorels "IDR" and seas "DXT" look different, and even without the $190 per pair price difference the seas looks more interesting to me. I am waiting patiently for those more knowledgeable than I to discuss possible applications of the tbcd/gb-dxt.
It's a pretty cool driver in my opinion.
So maybe you guys could figure out what you would like to see with this driver.
Here are some of my ideas:
Maybe something like DXT, W4, Dual RS225s? LR2 design?
DXT, Seas W15CY, Dual RS225 or RS180 in a Watt Puppy enclosure?
DXT, Dual W15CY open baffle, Dual Seas L16 ported in a slim ported enclosure?
Later,
Jed- Bottom
I vote for DXT, W4 and RS270. Second choice would be DXT, W15, RS270.
BTW, why is the RS270 not used in any designs around here (apart from cjd's threeways)?
I brought the RS270 around the world so pleeeze I hope anyone build something with it! :B :rofl:- Bottom
I'm somewhat disappointed and surprised by the fact that the DXT can't support a real low crossover point. On this point, it is worse than the current favorite SEAS tweeters and the RS28. I thought that this was 1/2 the reason for a waveguide. Any thoughts?
Jonasz,
The RS270 is a great driver. CJD had some of our's jaw on the floor last weekend with the bass it was producing in a sealed config. It is just a BIG driver and likes BIG boxes. Most of the projects you see are smaller to meet Wife/Spouse approval.- Bottom
Originally posted by ---k---I'm somewhat disappointed and surprised by the fact that the DXT can't support a real low crossover point. On this point, it is worse than the current favorite SEAS tweeters and the RS28. I thought that this was 1/2 the reason for a waveguide. Any thoughts?
Jed- Bottom
Originally posted by JonaszI vote for DXT, W4 and RS270. Second choice would be DXT, W15, RS270.
Originally posted by JedEveryone says they need large boxes, but I wonder how the bass would sound in 60L ported or 50L sealed?- Bottom
You looking for a new project Jonasz?
Would love a RS270, TB and DXT design! :P- Bottom
Jed,
Maybe in a few months I could sell you 4 used RS270's for a good price!
No extra charge for the scientifically implemented "break-in" period.- Bottom
Originally posted by ---k---This place is warped! Since when is 60L not BIG?- Bottom
I like the sound of those projects Jed. I would probably opt for the dxt, w4, and dual 225's. Or dual Seas L22's? I haven't seen these used much and was just wondering how they match up against the 225's for a project like this. The 270 has always made me wonder too!- Bottom
It might be more appropriate to put the W4 in a computer speaker than the Seas W5CY, but then again I guess it depends on the design goals. Lately I've been playing around with a 3-way that uses 2nd order slopes and it definitely is smooth sounding.- Bottom
Originally posted by SilversmokyI like the sound of those projects Jed. I would probably opt for the dxt, w4, and dual 225's. Or dual Seas L22's? I haven't seen these used much and was just wondering how they match up against the 225's for a project like this. The 270 has always made me wonder too!- Bottom
Ya I saw that sale and was thinking about just picking up a few for whatever future projects might come along. I have always been impressed with them.
I always thought that the L22 would LOOK great matched up with a w4 just had never really heard any feedback about there performance. Your Lineup maxx tower design with the w4's and L16 always catches my eye!- Bottom
BTW, why is the RS270 not used in any designs around here (apart from cjd's threeways)?- Bottom
Originally posted by JonaszDo you think the RS270, TB, DXT combo would be able to make a 2nd order design?- Bottom
Originally posted by JonaszBTW, why is the RS270 not used in any designs around here (apart from cjd's threeways)?
Sounds good Brandon. I just check out your tests of the RS270 and it looks really good. I think I could cross that as high as 400-600hz. Nice flat response and great sensitivity. Looks comparable to my Aurasound NS10s besides the Xmax limitation. I have a few questions though. What size enclosure are you going to use for the RS270 and why not go for a passive 3-way especially since you're going to cross around 200hz?
Jed- Bottom
Going active gives me a lot of flexibility regarding BSC and tonal balance. And I get rid of a big inductor. I have to do some modeling and measurements before I know exactly what I'll do. Many factors to balance...
I have no final box volume yet. Messing around the other day I think 75l tuned to 26Hz was well balanced, but nothing final yet.
So how is the SS 9800 treating you? You should post an update in your thread.- Bottom
Yes, considering the W4-1337 is great fullrange, I bet it would work really well LR2 in the bandpass. The only concern I might have is how high the RS270 can go.- Bottom
Sorry to bring the thread back on track , but - what do you guys think of this tweeter, then?
I like the idea of basically identical FR up to 30° off axis... that is something I'd like to try. But I'm a bit worried about the lack of very high frequency response. Can it be assumed that the real sensitivity of this tweeter is around 90 dB? Perhaps 88 dB?
My next project will definitely be a big WMTMW or MTMWW with a pair of RS225s, RS150s and the RS28s. If this tweeter can handle 2 KHz, I'd definitely use them instead of the 28s (as much as I *love* the 28s)... it looks great and the DXT documentation is very intriguing.Javier Huerta- Bottom
Making a little bit of progress. Here is the DXT's distortion expressed as a percentage. I tested it in a 20L Madisound box.
Looks pretty much like John K.'s results in terms of non-linear distortion. I haven't tested the impedance or IB FR.
It's not bad for a non-ferrofluid tweeter but definitely not state of the art below 2k in terms of 3rd order harmonic distortion. I will take John's advise and try this tweeter with a 27 series ferrofluid motor. That should really improve the low end and allow a nice 1.5kish 4th order slope. I think Seas recommendation of a 2k Fc is spot on and this tweeter will perform really well in that regard.
Jed- Bottom
I'm confused. The DXT already has the 27 motor, just without ferrofluid correct?- Bottom
Originally posted by augerproI'm confused. The DXT already has the 27 motor, just without ferrofluid correct?
Correct, I bought a H1212 pair to swap motors with the DXT. I should have said a 27 series motor w/ ferrofluid (edited post above to reflect that fact).- Bottom
