Help me find drivers for mid-bass arrays
  • Jman
    • 11
    Current setup-
    Mackie HR824 studio monitors L/C/R
    IB subwoofer - four 18" Avalanche drivers
    So the IB will cover 10-80hz, midbass 80-200hz, mackies 200-20khz.
    For the midbass I want to build a pair of arrays in dipole config.
    I'd like to use 4-6 12" drivers in each to minimize the load on each driver and keep the excursion low. What drivers are well suited to dipole use and somewhere in the $50-75 each range?
    thx
  • Paul W
    • Oct 2004
    • 552
    Haven't used it yet, but the Peerless SLS 830669 looks like a very good value and should work well in your application.
    Paul
    • chasw98
      • 1360
      Look at the Dayton/Parts Express 12 inch RSS315HF 8 ohm.
      I am using 2 per side in a dipole with a DIY passive EQ circuit before the crossover and they provide very nice mid bass. I am going from 80 to 250.
      • Jman
        • 11
        Looks pretty good. Is that my best bet for the $$$?
        • Jman
          • 11
          chas-
          that's a better driver but twice the price
          • Jman
            • 11
            Any other suitable drivers? Should I consider 8" or 10" drivers?
            • Nemophyle
              • 40
              you wont find a better value than the sls IMHO, except maybe the dayton, wich is twice the price, but also almost twice the excursion.
                • 1456
                Maybe 4 of these:
                RS270
                Or 4 of these:
                RS225-8
                Dan N.
                • whoaru99
                  • 638
                  How 'bout some JBL pro audio drivers for this application?
                  They seem to offer plenty of power handling and punch.
                  ----JAFFE'S PRECEPT
                  • Jman
                    • 11
                    Originally posted by dlneubec
                    Maybe 4 of these:
                    RS270
                    Or 4 of these:
                    RS225-8
                    My friend mentioned those 8" Daytons and I saw the 10" version while mulling about PE.
                    For the range I want to run them (~60 to ~250hz), what would be the ideal driver size? Would 12 of the 8" drivers be more than enough for movie reference level? I need something that can keep up with my IB sub. Don't forget I want to do dipole not sealed.
