Is it possible that my less than amateur soldering skills killed one of my tweeters? I have two new Seas D26NC55 tweeters sitting here. I didn't test either prior to attempting to install them.
The first one is dead. Because the terminals are so small, I attempted to solder some 14ga wire directly to them. I hooked the speaker up, with the crossover and nothing came out from the tweeter. I unhooked the crossover, and attached the leads directly to the wire, no sound. I unsoldered the wires and hooked the leads to the tweeter, no sound. I get absolutely no sound from the tweeter, no static, no hiss, no nothing.
The second one, I put the leads on the tweeter directly, and played some music at very low volume. It sounded fine.
I also soldered the wire directly to the TB W4, and it seems to be okay. So, I can't be all that bad.
So is it more likely that I damaged the tweeter or I got a dead one from Madisound?
