Hi all,
A recent visit to a friend in Indiana left me feeling a little inadequate in the subwoofer department (I only have a Polk PSW303 with an 8" driver and a 100W plate amp). I tried, but there was no way I was going to talk my wife into a seven-foot-tall sonotube sub...
After looking around on this site I was inspired by Darren Thomas' sub, which has the outward appearance of a mild-mannered cabinet. Then I saw Thomas recommending the Tempest-X 15" subwoofer to many builders on the site, so I thought it would be a perfect match. I got my wife's blessing and now I'm ready to start.
My plan is to build a big sealed sub. Following the application notes on the DIYCable site, I figured I'd shoot for a volume of 200L (my current drawings are coming in at ~185L after the driver and bracing volume is subtracted). I can't go too much larger. I could go smaller, but given the faux-cabinet design there isn't too much point to that either.
Before I get too far along, I'd like to toss out a couple of questions with the hopes that you folks will give me a few pointers.
First, does the above plan sound reasonable? If you were tackling this project what would you do differently?
Second, in their application notes the DIYCable guys recommend the 500W amp from PE and say that the 1000W amp won't be needed. Should I heed this advice? Will the extra $100 on the 1000W amp just be wasted money or do I actually have to worry about destroying the driver? I was always under the impression that more power is better when it comes to subs.
On a related note, how does everyone feel about the 500W PE plate amp (HPSA500)? Should I be looking at the 500W Keiga amp at Madisound instead? Is there another that would be better?
Last question for now. The driver will fire down. Is there a rule for how much distance I should allow from the floor to the baffle? From Darren's pictures it looks like he left about four inches or so.
Okay, that's it for now. I continue to update and post pictures as I progress!
Thanks!
Alan
Thanks!
Alan
