I recently decided to start building my own HT setup...I have decided to go with CJD's MTM for the fronts and center initially. I am going to be building the sealed versions because i am planning on building a sub as well. I currently have a 15 kicker xpl sub that i bought a few years ago, and all its doing is sitting in the garage. Specs from kicker recommend putting it in a 2.7cf sealed enclosure. More than likely I'll be paring this sub up with a crown amp from FleaBay. My question is....is this sub going to be able to perform in a HT enviroment, or should I not even bother with this sub?
Sub ?
Tags: None
It's impossible to answer your question without seeing the T/S parameters for the driver.
unfortunately this only info I can find on this sub is the following
Model Size (in.) X15c
Impedance (ohms) 2, 4, 8
Maximum Amplifier Power (watts)* 600
Sensitivity (dB 1w/1m) 90.0
Frequency Response (Hz) 23-500
Recommended Sealed Enclosure Volume (cu.ft, l) 1.8-2.7, 50.9-76.4- Bottom
alright so i called Kicker and got these specs for their 4 ohm version...
FS: 19.097
PE: 600W
Qes: .506
Qms: 11.338
Qts: .484
RE: 2.950
Sd: .0845
Xmag: 10.353
Xmax: 10.353
Vas: 430.4220 cu liters- Bottom
Well, since you already have it, it's worth building a box for and it will sound tons better than no sub at all. However, the 10mm Xmax means the output is going to be somewhat limited compared to the big boys. If you could sell it for a decent price, there are better drivers out there like the Tempest-X.- Bottom
It may not perform with the best, but it will be fun to play with, and a
good learning experience.
Throw it in a box, and add a M&K amp from Apexjr
The good part about a specific Sub amp is that it has filters built in, a
handy bass level adjust setting, and a phase adjust as well.
herm- Bottom
Or this MCM amp
MCM has this 300 Watt sub amp on special for $89.99
Check out that toroidal!
"While we're at it" - the four most dangerous words in Home Improvement- Bottom
