router cutting question
  • prho
    • Nov 2007
    • 9
    i have a hitachi m12v and a jasper jig i want to cut a 5-5/8 inch circle but i think it doesn't cut that small am i wrong?
    • 5204
    yes.
    I used the Jasper 200 Jig over Christmas to cut the holes for my RS150s and tweeters. I did have some issues, because of where the router base plate mates up to the jig, you can push the center pin all the way through the hole in the jasper. I was just very careful and did it with the pin just barely in the jig.
    Should be do able. But, a homemade jig isn't that hard to make from scrap wood. Just copy the Jasper and modify as needed.
    • prho
      • Nov 2007
      • 9
      let me rephrase that, does the combination work? has anyone cut circles that small with the jig and hitachi?
      • prho
        • Nov 2007
        • 9
        ok i think i understand you. just barely put the pin in basically the depth of the jig.
        • gmed
          • 207
          Jasper Jig should work with all if not most of the routers, and yes, you should be able to cut that size.
            Correct when you're cutting circles smaller than the router's stock base, frequently the pin can only be inserted the thickness of the jig
            • Eton
              • 31
              For odd circumference circles you will need something like the jig I built few weeks ago.
              • prho
                • Nov 2007
                • 9
                thank you all.
