I have Stryke AV12 in an enclosure with 2 15" PRs powered by a 350 watt plate amplifier. I have two identically built subs in this configuration. One of them is having a few issues.
1) When played at low levels I hear a clanking or rattling noise like the driver is bottoming out, but the driver is barely moving so I'm not sure what it could be. Any ideas?
2) When the sub is plugged into the wall with or without sound input there is a hum. I'm fairly sure this is not ground loop hum because my other subwoofer does not exhibit this problem. Could it be a "bad" amplfier?
Thanks for any input,
