Custom subwoofer
  • wurm_usmc
    Custom subwoofer
    I am a marine and kind of limited on supplys i have a klipsh promedia 5.1 system the amp or something stoped working on it. the speakers are still good, so i have plugged them into a reciever and am currently using them as a home theatre they work great. Except for the sub. it is a box with two 10" inside and need a way to make it work with my system. The reciever only has a subwoofer preout i want to make it work with out buying an amplifier if it is possible or if someone knows how to use the built in amp. Any advice would be much appreciated. Semper FI!!!
  • Sdiver2489
    • 77
    FYI the sub is a dual 8" design.
    Secondly, a sub preout means that there is no amplifier on that output. If that's the only output the receiver has for a subwoofer then you need an amp.
      • 5204
      If the speakers work well when hooked directly to the receiver, it sounds like the amp in the sub amp is having problems. Unfortunately, there likely isn't a way to fix it easily. The Klipsh site mentions that the system uses a 500W Bash Amp - it may be similar to this: http://www.partsexpress.com/pe/pshow...TOKEN=24269734
      You could try replacing the amp, but Klipsh may have some custom EQ in the amp that wouldn't be in the replacement amp. The best solution for you may be a new sub. The PE Dayton 12" always gets good reviews for low budget subs: http://www.partsexpress.com/pe/showd...number=300-635
        • 5204
        Also make sure your receiver has a set-able crossover. Those Klipsh probably like a ~120-150hz crossover. If your receiver is hardwired to 80hz (like many cheap receivers are), then you may not like the results.
        Unfortunately, those HTIB type systems aren't designed to be upgraded, repaired. Just used and thrown away.
        • Sdiver2489
          • 77
          doubtful considering that amp costs about the same as that entire speaker system
