I have built the RS150 design with the following crossover http://www.htguide.com/forum/attach...tachmentid=9526
Since I built the BSC version (for future placement), I actually have the speakers in a less than ideal location for now. Because of this, the bass and midbass is very warm. I would like to change the tweeter attenuation values to actually brighten up the top end.
I have researched until I am blue in the face and come up with differeing opinions on whether only changing the series resistor value would alter phasing or pass freq. I would like to try changing the 4ohm series to maybe a 3.5 or 3 ohm - Will I need to alter the parallel resister also to keep things just as they should be regarding phase and cutoff??
I would be very appreciative if you have any thoughts to share!
Thanks, Sean
Thanks, Sean
