So.for those of you that have used the RS52 and the CSS WR125s, which do you think I'd be better off using in a 3 way using two Extremis 6.8s and either the Vifa D26 or BG NEO3PDR? I see alot of people raving about the RS52 but would it be susbstantially better than using two CSS125s per speaker? I think that I would like to cross the Extremis's pretty low, something between maybe 300-600 and wouldn't want to go any lower than 2700- 3000 on the tweeters. I plan on 40-42 liter cabs. Also I'm considering going active on the Extremis to keep from having to pad down the mid(s) and tweeter as much. So what do you think? Pls don't try to talk me into a different Woofer or tweeters. I already have them and four WR125s so I'm just considering using the RS52 in place of the WR125s and whether or not I need to go active on the Extremis/
Thx
Thx
