No, this has nothing to do with Klipsch speakers; what I'm wondering is if the Zaphaudio waveguide TMM design might be adaptable to a pair of enclosures I have which will soon be vacant of drivers. These happen to have the same baffle width of about 9", but the thing is that Zaph's design uses two separate enclosures for the top and bottom mid/woofers, both of the same volume (.69 cu. ft.) and tuned to the same frequency (between 46 and 51 hz, depending on listener preference).
My cabs also have two separate enclosures, but the one the top woofer would be in measures ~.5 cu. ft., while the lower enclosure for the ".5" woofer is about 1 cu. ft. Now I'm guessing that in order for the 2.5-way design to work correctly and provide enough baffle step compensation, the 2 woofers must always be tuned to the same frequency. Is this the case? And could I accomplish such a thing by using different-length ports in the .5 and 1 cu. ft. enclosures?
Further heretical question: if the 2 woofers don't need to be tuned equally, could I use a ~46 hz tuning for the lower BSC woofer and maybe use one of these Scan-Speak Variovent things that I happen to have lying around for the top woofer enclosure?
Sorry for the weird questions, and thanks in advance for any help!
