Now that I'm up and running with SoundEasy I want to tackle my first passive speaker project, which will be a thin floorstanding MTM for my brother. I have 4 RS125s sitting here along with a couple of the Vifa XT25SC50-04 neo ring radiator tweeters so I am thinking of doing an MTM with them spaced very closely (almost touching) with the tweeter to their side. Looking at Zaph's distortion measurements these guys can get rough under 2khz but wanting to make sure I took my own distortion measurements which came out just a tad better than his. Right now I'm thinking of crossing them over LR-4 around 2.5khz but if you think I should go higher or could take them a little lower please let me know. I'll probably build them ported since they'll only need a little over 0.3 ft3 so if he wants to add a sub later on he can stuff the port and have an F6 right at 80hz, making it not too hard to cross to the sub.
Here are the distortion plots I took. They are labeled from 90 dB @ 1 meter up to 100 dB @ 1 meter. He does like to listen to loud rock once in a while so we may need to take that into consideration with the crossover point and the strain on the tweeter.
Thanks!
90 dB @ 1 meter
95 dB @ 1 meter
100 dB @ 1 meter
Thanks!
90 dB @ 1 meter
95 dB @ 1 meter
100 dB @ 1 meter
