Need some turntable help
  • augerpro
    • 1866
    Hi guys. I just finished my new music room where I'll be listening to my bookshelf speakers I just finished. Anyhoo, I got a TT for the heck of it. It's an NAD 553, a Rega P2 clone. My problem is when I lower the needle onto the platter it just slides straight to the center! I have two little levels that confirm that the platter is level. I didn't think there was anything pushing the arm correct? Also under the little red NAD emblem is a slide switch of some kind, it's labeled 0,1,2. What's this for?
    Sorry for the blurry pic. I tried several distances and turned the flash on and off but it must have just been to dark for the camera. Thanks for any advice!
    EDIT: the TT is an NAD C555
    ~Brandon 8O
    DriverVault
    Soma Sonus
    • 10931
    If the stylus doesn't track you need to adjust the amount of pressure. Zero out the balance, then dial in the amount needed for your cartridge (turn the counter weight on the back of the tonearn).
    The owners manual talks about a 'bias' control (probably means anti-skate), and says it's set to the same weight as the stylus.
    • augerpro
      • 1866
      Thanks Thomas for the help. So if I adjust the counterweight to 1.7g as suggested, I should also set the bias slider to 1.7g? What does the bias slider bias? Should it be set to 0 when I adjust the counterweight, then set to match whatever I set the counterweight to?
      ~Brandon 8O
      DriverVault
      Soma Sonus
        • 10931
        I just looked at the manual onlne.
        I've never heard of 'bias' but that's what they call the switch in the manual, so I'm guessing it's anti-skate.
        Usually one sets the anti-skate to '0", then backs off on the counter-weight until the arm balances.
        Then dial in the appropriate amount of weight and set the anti-skate. If there's a setting for the bias to 1.7 do that otherwise try 1 or 2 and see which sounds best.
        I used to have a special Telarc record set where one side had no grooves. One would set the needle on that side and adjust the anti-skate so the needle stayed in one position in the middle of the record.
        • Ray Collins
          • 257
          Augerpro,
          Thomas is correct....also, check your stylus. The stylus and area around it can become matted with dust/etc. It may need to be brushed so that the stylus is the only point touching the record. Without a stylus gauge I would adjust the counterweight until the arm hovers parallel over the record surface....then set the counterweight scale to zero. Next, set the appropriate tonearm weight according to the cartridge manufacturer's specs. Not exact but in the ball park until you purchase a stylus gauge etc. Anti-skate usually matches gram weight setting or less...depends on the arm.
          I also suggest placing a mirror on the platter surface and setting the stylus/arm in the center of it. You can check for perpendicular lie by looking head on and for rake from the side. Tinker with it until it "drops in",i.e.,it will sound "right". Believe me, you will know.
          Ray
          BENJAMIN FRANKLIN
            • 3791
            Just to clarify what these guys are saying, what your tonearm is doing is "skating", i.e. it will move across a record with no grooves. So you need to adjust the "anti-skate" control. No idea what NAD may call that control.
            • augerpro
              • 1866
              I adjusted the counterweight properly and everything is all good now! I forgot I had messed with it when I first got the TT, and had it backed off too much so there wasn't enough weight on the needle.
              ~Brandon 8O
              DriverVault
              Soma Sonus
