Hello all,
This is my first post. I've been reading and researching for awhile and hope someone will be interested in this.
I have four Audax HM170C0 6.5" drivers that I'd like to turn into a vented MTM with the peerless HDS 810921 Tweeter. I am thinking around 2K for the crossover, I was thinking a 4th order L-R filter for both the low and high pass in parallel.
The boxes are built. I oversized a little for adjustment later. Internal volume is about 30L. The baffle is 9 1/4" W x 21 7/8" H. Tweeter is located 11 1/2" from bottom of baffle and centered between the edges. The ports are 2 5"x2" pvc per box. These will have to be adjusted as well.
I originally had Madisound do a LEAP design but that turned out very bad. It had a serious dip at 2.8K, the crossover section. Also the tweeter was about 8db down from the level of the wooofers. Plus they sounded terrible. I don't have my measurements from that assembly otherwise I would post them.
I've posted some FR and IMP measurements of the drivers on the baffle.
One of the caveats for me in this process is that I am using a mac. I have virtual PC running Windows 2000 and am able to use software like Speaker Workshop and Spl tools and what not but I haven't been able to make an accurate trace of the impedance of the drivers using SPL Trace. The ohm scale is always not accurate no matter which scale I set in the Tracing options and hence I am unable to produce usefull .zma files. I am able to export .frd for the drviers from Fuzzmeasure, but it does not have an ablility to export zma files. I guess I am asking for help in where to go from here. I would love to be able to model the crossover myself but I can't get the correct .zma files that would be needed in a program like Speaker Workshop. I could go ahead with pencil and paper and a couple of years but it would be nice to some optimization before I start buying parts.
If anyone has some suggestions I would greatly appreciate it. Please pardon such a long post. I have been a reader of the forum for greater that a year now and I'm ready to go out on a limb and start designing for myself-diy style.
Nathan
Nathan
