I'm thinking about getting the Hitatchi KM12VC kit that has a plunge base and fixed. My only problem is it has no form of dust collection at all. So I thought I'd ask if anyone knew of a pretty nice plunge base router with dust collectionf or <160? I'd like something I can just hook up to a shop vac for the most part.
Looking for a cheaper router with dust collection?
Look for a refurbished DeWalt 621
I have the Dewalt 618 fixed/plunge set. The dust collection isn't as good as the 621, but it works pretty good. The only problem I have is trying to route circles with a shop vac attached. It's a pain in the arse!
What I do now is set up my table right next to my garage door and put my big fan on another table right in front of me, and it blows everything right out the door. The neighbors haven't said anything yet. 8O- Bottom
They're not always available. Check the Tool King website that's where I bought one but it was years ago.
I have both a 621 and 618, there's no comparison, the 621 dust collection is significantly better...
Don't kid yourself. Anyone that's ever used the 621 (like me) knows that the 618 sucks (or doesn't, actually).
GET A 621!!!- Bottom
Dougie,
what are you using for a work table? I didn't know if a simple dust hood clamped to the side would work just as good if not better for you, or a possible downdraft table? Either can be done easily.
Robert P. 8)
AKA "Soundgravy"- Bottom
Just using a workmate in an empty room most likely. Going to cover the floor with plastic and route everything there. Why I was looking for something with a nice dust collector. It's getting cold and raining all the time up here they are talking about snow in a week or 2 so going to be doing this in doors for sure.- Bottom
I know it's no Hitachi or Dewalt and that others may dismiss it as lesser quality, BUT I really like my Black&Decker (Firestorm) FS1200RP. http://www.blackanddecker.com/Produc...roductID=14874
It has decent dust collection, a 12 amp motor, and accepts both 1/4" and 1/2" router bits. It also has soft start and variable speed control. If your budget was <$80 I would highly recomend getting one but at $160 you should be able to find a better unit.
Good luck.- Bottom
The 621 has the best dust collection of any router I've ever used. That said if you're running an edge or plowing out a dado there will be dust that's not sucked up.
Originally posted by Dougie085Ok I went ahead and ordered a new DW621 I found one for 203 with free shipping and from an authorized dealer at that.
If you're forced to route indoors, (I only do that if there's absolutely no other option) think about using one of these collectors in addition to the 621's built in collection system.
You will need an adapter to reduce the diameter of your shop hose to match the 621's output hose. The 621 has a swivel at the top and is very friendly in allowing you to move the shop hose around when routing....wear a mask.
RayWine is constant proof that God loves us, and loves to see us happy.
BENJAMIN FRANKLIN- Bottom
I would highly suggest getting a regular particulate respirator with the replaceable cartriges, not a paper dust mask, those are next to usless. Maybe this is what you were talking about, but I just wanted to make sure, they're about $25 at Home Depot or Lowes. Also, if the room you are working in has forced air heating, shut or better yet cover the vents while you are working in there and don't open them again until after you have cleaned everything up. If you don't that dust will get sucked into the HVAC system and your whole house will get covered in dust, or so I have heard.- Bottom
Or . . . you could try a Milwaukee Model 5625-20 (3-1/2 Max HP) Fixed-Base Production Router, and wear a good mask like Brian suggested (I use a North respirator), and if you don't want to bother your Harley neighbors like I do and have to work in closed workshop, just let the dust accumulate for a couple months, and then blow it out with something like my trusty old Tornado blower---on a breezy day, of course.Steve- Bottom
Don't know about the effectiveness of its dust collection mechanism, but Freud is supposedly clearing excess inventory on their FT2200E Variable Speed 3-1/4 HP Plunge Router. It's selling between $120-$130.
Woodcraft stores sell it for $129.99 (call first to check availability), Hartville Tool (no experience with the company, somebody else referenced them) is $125 incl. shipping:
HartvilleTool.com is now HartvilleHardware.com! Same company, same service, same brands, but much bigger selection
Does anybody here have this particular router (or its similar model FT2000E)? I already have a nice Bosch 2-1/4 HP router, but at this price I may just have to buy the Freud for dedicated router table use. Somebody here (Jon?) I think said that you cannot have too many routers!
BTW, not that it fits the OP's objective of a cheaper router, but Festool makes some of the best tools period, and their dust collection capabilities are phenomenal (I own several of their tools, though the router is still on my wish list). Again, not inexpensive by any means, but I consider good tools to be an investment.
Frank- Bottom
I've not nor do I know anyone who's used Freud tools, but I don't recall ever reading anything negative about them.
That's a great price if one want's a big router and doesn't need dust collection... :T
Sears also has a Craftsman model plunge router with digital depth adjustment and dust collection. IIRC, it runs around $160. I've been tempted to try it since I can pick it up locally. I think the main thing that makes me hesitate is that if the dust collection doesn't work well I'll be pissed and then will have to fool around with returning it.
I used to use the DW621 indoors all the time and it did a phenominal job as long as the vacuum system wasn't full!- Bottom
Hitachi router on sale at amazon:
http://www.amazon.com/Hitachi-KM12VC-Horsepower-Variable-Collets/dp/B0002ZZWX8/ref=sr_1_15/105-4117963-7740405?ie=UTF8&s=hi&qid=1193448447&sr=1-15
http://www.amazon.com/Hitachi-M12V2-Horsepower-Variable-Collets/dp/B000GKC28W/ref=sr_1_9/105-4117963-7740405?ie=UTF8&s=hi&qid=1193448447&sr=1-9- Bottom
Well I'm not going to be routing inside anymore going to do it at a friends house. I'm looking at circle guides and I know the jasper jig is popular but I was looking for something more sturdy and long lasting other then the plastic one.
Does this look decent? Or are there any others you guys can recommend?- Bottom
Originally posted by Dougie085Well I'm not going to be routing inside anymore going to do it at a friends house. I'm looking at circle guides and I know the jasper jig is popular but I was looking for something more sturdy and long lasting other then the plastic one.
That thing looks like it is optimized for large circles. The jasper jig works perfect and is very accurate.- Bottom
Infinitely adjustable jigs will do more than the Jasper. But for speaker building nothing is faster or more exact for repeated cuts than the midsized Jasper.
Originally posted by Dennis HBlock the bottom of the door with a towel. Your SO will thank you. MDF dust is really nasty and goes everywhere.
Probably a good idea to pay more for the "better" shop vac bags... I can get ones supposedly good to 1 micron for my Sears vac. Good to not have the finer, more hazardous particles passing thru the vac and blowing all over.
Something else that might help to reduce the cleanup. I've found that a standard window fan and a 20"x20" furnace filter can do wonders. Just turn it on, and the suction holds it to the fan, no tape required! When it gets dirty, go over it with the shop vac, it will last quite a while. I use it a lot when I'm sanding... sit in front of it, most of the dust goes into the filter. Leaving it on for several hours should get a lot of the floating dust, too. Probably better to go higher quality for finer filtering, but since I'm outside or open garage, I get the cheaper ones.
Hope that helps...- Bottom
Originally posted by JonP
Something else that might help to reduce the cleanup. I've found that a standard window fan and a 20"x20" furnace filter can do wonders. Just turn it on, and the suction holds it to the fan, no tape required! When it gets dirty, go over it with the shop vac, it will last quite a while. I use it a lot when I'm sanding... sit in front of it, most of the dust goes into the filter. Leaving it on for several hours should get a lot of the floating dust, too. Probably better to go higher quality for finer filtering, but since I'm outside or open garage, I get the cheaper ones.- Bottom
You better finish before it starts snowing here Dougie! hahaBE ALERT! The world needs more lerts.- Bottom
Yeah trying. I think next weekend I'll be finishing up the cabinets. All the rest of the stuff is on its way now. Router will be here tomorrow. I can't think of anything else I need to order other then finishing materials but that can wait.- Bottom
Originally posted by MazerothFantastic idea! I'm going to have to give this one a shot. Thanks! :T
I even used it in my spraying "alley" (cardboard sidewalls, painting paper floor, fan and filter at the other end) for the can spraying and innumerable coats of HVLP shellac on my current project. Did help to catch the majority of the overspray. That really used up filters fast though, and it won't vac clean like the dust... probably want to stick with the $5 ones there!- Bottom
For someone who really knows his stuff on dust collection, check out Bill Pentz' site:
His Docs Orders pages tells about medical risks as well as what woodworkers can do about them:
Steve- Bottom
Sorry to resurrect this old thread but I remember reading it and my post pertains to it.
I just snagged a brand new DeWalt 618 fixed/plunge kit for $100 brand new off Craigslist. It sells for $328 on Amazon:
I have no idea why he sold it to me so cheap but it's brand new! What I'm wondering is if I should ebay this guy and put that money towards the 621 model with the better dust collection? I'm currently using the Ryobi RE180PL plunge model that Home Depot sells for $99 and it does a great job but I'm looking for one that will do dust collection. I'm not sure if having a separate fixed base router is worth it so the DW621 is looking mightly tempting. This will be used out in my garage and also outside so collection doesn't have to be 100% but close wouldn't hurt! :B
Thanks.- Bottom
Originally posted by MazerothI just snagged a brand new DeWalt 618 fixed/plunge kit for $100 brand new off Craigslist. It sells for $328 on Amazon:
