Unwinding an inductor
  • Inu_Yasha
    • 256
    I got all my parts in for my Nat P, but I need to unwind one of the inductors to reach a value. I remember someone posted a website that said how much you had to remove in order to reach a wanted value. The type of inductor is a steel laminate.
  • TacoD
    • 1080
    I think it's not that easy, the iron core is not specified. So calculating the number of turns to take off is not straight forward. You can better use a LCR multimeter.
    • mrogowski
      • 55
      Agreed. There are a lot of variables.
      Where no sound has gone before
      • jimangie1973
        • 92
        I use LIMP (the impedance measurement portion of the ARTA software package) to measure the impedance while unwinding inductors. All you need is the free version of the software, a resistor (preferably measured with a Ohm meter, I use 25 Ohms), your preamp/amp combo, and cables.
        The SW plots the inductor's impedance magnitude and phase. Since at higher frequencies, the inductor phase is very close to +90 degrees, you can just use the magnitude and the equation magnitude = 2*pi*f*L.
        So if you need a 2 mH inductor value, the impedance magnitude at 1 kHz needs to be 2 * pi * 1000 * .002 = 12.57 Ohms.
        • Undefinition
          • 577
          Boy was I happy when I realized Speaker Workshop can measure inductors and capacitors. Made unwinding a whole lot easier. Granted, a half-decent LCR meter only costs like $50. But that's money that could be put towards more drivers!
          • Inu_Yasha
            • 256
            True true. I just guesstimated on how much needed to be removed from the inductor. I found a website that had a program that told me approximately how much to unwind. Thanks for the info though guys, I didn't know that steel laminate would be so different than air core.
