"Extras" needed to build a crossover
  • Inu_Yasha
    • 256
    It's been quite a while since I've last posted. I got my boxes ready for the Nat P's and I am ordering the last pieces of the crossover sometime this week. What other items besides the inductors, resistors, and caps would I need in order to put the crossover together? Often I see people using some sort of long clear thing like in this pic:
    What is that and where do i get some :P Is there anything else I'm missing? Also, on a side note, what type of binding posts do you guys use?
  • Kal Rubinson
    • 2109
    What long clear thing? I see a coil, a cap, some wires and a terminal strip. Also, something that looks like a flared port.
    Kal
    Kal Rubinson
    "Music in the Round"
      • 16073
      I think he's talking about the terminal strips.
        • joecarrow
          • 753
          Overlooked or handy items for building crossovers, in my experience-
          -Zip ties, good for attaching things to each other, and they don't shake loose.
          -Hot glue or caulk, not for structural use so much as to ensure that things don't rattle when they're held together with zip ties
          -Fine sand paper, it's good for clearing the ends of inductors if the enamel insulation goes too far and they aren't already nicely tinned.
          -A variable power soldering iron, even better is temperature control with decent power
          -Liquid flux, it really helps the solder flow and wet things
          I used the gold plated binding posts from Parts Express:
          They're probably overkill, but at least I don't stay up at night worrying that my sound is getting corroded
          You could go with just about any binding posts and do quite well- I've seriously left wires hanging out before and just twisted the bare wires together for a connection, and it worked. Spring terminals annoy me, though, as well as the screw-downs where there's not a good positive place to stick the wire through.
          -Joe Carrow
          • Inu_Yasha
            • 256
            Bingo, those are them. I didn't see any at madisound though (which is where I'm going to place my order). Are they available anywhere else? Also... what are they used for?
              • 16073
              Just to keep things tidy. You don't really NEED them.
                Madisound doesn't sell them which is why I posted the link.
                If you google 'Euro style terminal strips' you'll find more places that sell them.
                I wouldn't build a crossover without them...
                • Dean100
                  • Jan 2007
                  • 140
                  You can also get terminal strips at Radio Shack.
                  • evan
                    • Jan 2007
                    • 43
                    Are you guys using terminal strips instead of soldering, or in addition to it?
                    Evan.
                      • 5204
                      in addition.
                      Typically just for the input and woofer output.
                      • Troy R
                        • May 2003
                        • 36
                        I found the terminal strips at Lowes in strips of 12 for around $3-$4
                        • IllNastyImpreza
                          • 77
                          I wonder... can you cut them?
                          like if you only need 6 connections on each side?
                          • Brian Bunge
                            • Nov 2001
                            • 1389
                            Yes, a nice pair of wire cutting pliers, aka dykes, does the job very easily.
                            • IllNastyImpreza
                              • 77
                              awesome... I'll definatly have to pick some of those up when I build my Modulas ...
