I have a few boxes of the Aura NS3-193s sitting here and am going to build a pair of 6.5-7' line arrays for the basement theater in the house we just closed on. I'm stuck on which tweeter to use and think I will avoid the PT2C after a friend of mine did some distortion measurements on the new batch and they came out horribly. The two tweeters I'm considering are:
As of now I'm leaning towards the Dayton for these reasons:
1. They will cost me roughly half as much as the Aura tweeters
2. Their center to center spacing is tighter
3. Easier mounting
4. They have a rising response above ~16k, which could aid in the comb filtering due to the non-optimal spacing of the tweeters but will probably be negligable
What do you guys think? I'm thinking of crossing them to the NS3-193s between 3-4 khz. while the bottom few octaves will be handled by subwoofers. I will use as many tweeters as needed to match the length of the mid line, which should be somewhere around 50 per side (anyone want to help wire?). These will be used for 90% movies so the utmost in SQ is not needed, though, I would like them to sound very good.
One other thing I was contemplating was making them more full-range and adding a small line of these Tang Band subs to the side, probably 8 of them, with a little bit of spacing to allow them to go the full line:
Due to their lower sensitivity I would use a plate amp on the back of the arrays and utilize its crossover to save money on expensive inductors. Then I could make the NS3-193 enclosure sealed, find its F6 and try to cross around there (I'll measure, of course).
Thanks for any input you guys can give me! I really do appreciate it!
3. Easier mounting
