Angry Neighbors
  • Quwiksilver
    • Apr 2007
    • 32
    Angry Neighbors
    Hi guru's,
    The next door neighbors are starting to get upset. They're really nice people, and they've been very tolerant, but due to the way our houses are constructed and set up we have a truly nasty "noise pollution" problem. Here's the deal:
    I've got Zaph's L18 system in the living room. The living room is directly adjacent to their bedroom next door. Here's the kicker: both of our houses are made entirely of steel (more reading on the houses here). Even at a relatively low SPL, they can hear the music, or at least the bass line, throughout their entire house.
    The question is this: Apart from tearing out the walls and insulating (not possible; I rent) what can I do to reduce the noise radiating through the walls?
    Scott
    • 16075
    They have an insulation system that you can drill a small hole a put a hose in and fill it. Other then that I'm guessing a lot of bass bins otherwise and even so that may not help much.
    • Jonasz
      • 852
      Do you have dampingfeet under your speakers? Could be a good start to test that.
      • RV8guy
        I saw this stuff on TV http://www.quietsolution.com/html/qu...FTyKOAodWm4FBA
        edit: D'oh, I just saw that you rent. It still might work for you and nobody would ever know that room was just a little bit smaller than it used to be.
          • 10934
          Other than building a concrete wall between the buildings there's not much to do except turn down the volume.
          This is one reason headphones and tactical transducers exist.
          • technimac
            • 233
            How About Some Bass Shakers?
            :agree: with Thomas about Tactile Transducers
            Mounting a passel of Bass Shakers under your couch/loveseat/favorite chair etc will go a long way in helping you to experience some of the LFE you are actually "not" hearing. And more importantly, neither are your neighbors. :W
            (edit: I just checked PE's site and this is listed as, "In Stock? No, awaiting updated due date".......which often means that there are no more. You can always call to find out the status)
            Sure it's not the same as high volume, chest-whumping 18Hz stuff filling the room, but in your situation the options are very limited. :cry:
            Choose an amp that's suitable to power the number of Bass Shakers you install and you're good to go :T
            "While we're at it" - the four most dangerous words in Home Improvement
              • 10934
              I used 'tactical' as a bit of a joke. Guess I'll start labeling my jokes...
              • technimac
                • 233
                Ahhh......a secretly-encoded curmudgeon joke I'll bet.
                I feel a little embarrassed that I didn't even pick up on that. ops:
                  • 10934
                  The 'tactical-transducer' provides added low frequency response and eliminates neighbors lacking a sense of humor.... :B
                    • 15284
                    Scrap the existing system, build a dipole system, and set it up so that the side null points towards your neighbor.
                    Dipoles are probably the most PRACTICAL speaker type for those living in apartments, condos, and townhouses. That includes me....
                    • AJINFLA
                      • 680
                      Build a pair of dipole subwoofers as stands for your L18's. Maybe a shallow H-baffle 6-8" deep (easy to construct) with a pair of drivers (or more, depending on budget, size limitations, etc). Cross around 150hz.
                      cheers,
                      AJ
                      Manufacturer
                      • rickwa7
                        To control medium and low frequency (most penetrating frequencies) you will need MASS. (weight)
                        Try 1" thick sheetrock or better still 3" thick. Ceilings too.
                        To control the very high pitch frequencies is much easier. Fiberglass batting, or 1/4" or 1" thick plastic foam insulation from HOme Depot will do it.
                        • technimac
                          • 233
                          Try 1" thick sheetrock or better still 3" thick 8O . Ceilings too.
                          Uhhh......He mentioned above that he's renting :W
                          • Quwiksilver
                            • Apr 2007
                            • 32
                            Now there's a solution I can live with...build more speakers! :T
                            Now...off to find or design a quality budget dipole (gee...never heard that one before )
