I built a new sub which uses a pro amplifier. I decided I wanted to reconnect my old Velodyne sub back up as well to improve headroom. I used a y-adapter at the input of the proamp to daisy chain over to the old sub.
When I first turned everything back on I was getting a loud hum from the Velodyne. This sub always seemed very susceptible to hum. When I first got it, it hummed and Velodyne told me to use a cheater plug, and it worked. I reconnected the cheater plug to the Velodyne which helped a little. I then connected both the pro amp and the Velodyne amp through cheater plugs, which completely eliminated the hum at first. But, when the pro amps fan kicked in all hell broke loose. I do not like to use the cheater plugs anyway. I disconnected the old sub for now. The proamp by itself does not hum, but has a very slight hum in its transformer, if you put your ear up near the case. I am not sure what to do next. I tried connecting the two sub amps to different outlets but this did not work either.
Any suggestions?
Thanks in advance.
Any suggestions?
Thanks in advance.
