One of the next things I'd like to experiment is a _fullrange_ 2-way, meaning ~25Hz-30kHz. It doesn't have to be very loud and I've also pretty much given up hope for good efficiency. I want to take the XO-point out of the 1,5kHz-4,5kHz range and I see no way to have 25Hz extension from a driver that can nicely go to 5kHz. I've done some smaller projects with 4"-5" drivers up to 5kHz and I like them a lot. Now it's time to try what happens if the XO point is lower than the 1,5kHz-4,5kHz sensitive range. The bass will probably be handled by an RS225.
What I need is a "tweeter" that has extension to 20-30kHz and can work with a low XO-point with normal 2nd-4th order electrical slopes. I have a few options already:
The Jordan JXr6HD ( http://www.ejjordan.co.uk/drivers/jxr6.html ) or the J6T ( http://www.markaudio.com/j6t ):
+ Fulfills criteria
+ I love my JX92S's
- J6T horrible looking frequency responce
Other ~2" fullranges, e.g. TangBand's
+ Low cost
- What is the quality? Some at least look nice
Fountek NeoPro5i ribbon ( http://www.fountek.com.au/products/NeoPro5i/index.htm )
+ 2nd order xo @1,5kHz is ok --> can go lower with steeper slope I hope
+ I like my smaller Founteks
- Expensive
- Vertical beaming
Mark&Daniel style AMT driver ( ***WARNING*** AJINFLA down there getting Trojans *** http://www.mark-daniel.com/Dir_En.asp?Proid=13 )
+ Mark&Daniel liked at e.g. 6moons
- Drivers not available separately as they are modified somehow (?)
Planar midranges/tweeters like B&G Neo8-PDR and HiVi RT8-II
+ Cost is ok
+ B&G can go low in an enclosure
- B&G enclosure tuning might not be so neat
- How's the top end?
Is there other options? Horns? Compression drivers? Any comments on the previous?
+ Fulfills criteria
+ I love my JX92S's
+ Low cost
- Expensive
- Vertical beaming
+ Cost is ok
