Looking for views on sub design and driver choice for my music only system. I posted similar request on the AVS board. A few years ago Nick McKinney and Mark Seaton gave me some great design advice but I let it slip and never built it. It's time to start again.
1. Goal: integrate single box sub into existing high end, music only system. Musical fidelity is key; no home theater stuff. I realize that multiple subs would be best but I can't do it; one box only and I want to make it good.
System: ARC tube gear (amp and preamp with no bass management); SACD and vinyl.
Room: 35x15x9-1/2
Listening: full range of music. Decent but not insane SPLs. Much orchestral work but really low end organ stuff is once is a blue moon.
2. Mains: custom; focal audiom T5s with PHL 1240s in MTM configuration; ported 24x12x8 cabinets. My guess is they inch down in the 40-50 hz range.
3. Current plans:
Sealed or PRs? at the moment leaning in favor of simple sealed but would toy with the idea of PRs. Nick McK and Mark Seaton favored dual PRs a few years ago. I was looking at a couple of different Lambda drivers PB, SAL and TD15X, if memory serves me.
Max cabinet size: 25x20x20 external.
Xover: am hyper sensitive about signal degradation to the mains but feel that a high quality high pass makes sense to filter the mains for the obvious reasons. Thinking either Bryston or Marchand active xover (cheaper brands spook me). Am not impressed with the cheaper Velodyne, Rane, Reckhorn, Behringer products (but could be convinced otherwise).
Rythmik's site says all the right things about fidelity and the servos look cool but my instinct is they are not right for my setup. Their passive xover plug looks interesting but it has a 100Hz xover point and a very shallow slope. I am thinking instead of a more common 60-80 Hz xover with 12 or 24db slope-- symetric. I assume the lower xover point should increase flexibility with the driver choice (i.e., some of the monster excursion drivers may work for me if I keep them away from the 100hz and above range).
Amps: would use Crown or QSC-- am not picky on this front.
Drivers:
1. TCSounds LMS 5400
2. TCSounds 3000
3. Rythmik 15" servo (but this would entail using the servo plate amp as well; by the looks of it appears to be similar to the TC Sounds 1000 with servo sensing coil installed; althought the servo looks cool, this seems better suited to higher xover points and smaller satellite speakers and I could do better with driver and electronics quality)
4. CSS SDX15 (new; low inductance is one of the selling points; but with a 60-80 hz xover, who cares?)
5. old stock Lambda, eg the TD 15x (assuming they exist)
6. Apollo and TAD drivers were recommended but I know nothing about them
7. Dayton Reference RSS390 HO 15" was recommended (maybe with 2 per box).
4. Budget: none; if the results and quality justify it, then I'll do it...
5. Cabinets: max size= 25x20x20 external; will have someone else make them.
Recommendations and views would be greatly appreciated.
Room: 35x15x9-1/2
3. Current plans:
Drivers:
2. TCSounds 3000
