Some questions for ThomasW on building an AS-15
  • Adam321
    • Jun 2007
    • 37
    After having some trouble sourcing a 24" piece of sonotube I have decided to build a copy of the AS-15. So the questions begin. First I couldn't find what the AS-15 is tuned to. I would like to tune mine to about 16Hz. It seems that it would be difficult to fit a 6" port long enough to tune it to this frequency.
    Also, what does the AS-15 shown on the KLONE website weigh? I would like to keep my weight down. So I was thinking of using only three braces instead of four and instead of going with two layers of MDF going with one layer and a second layer of 1/2" OSD. Similiarly on the front and back going with 2 layers of 3/4" MFD and one layer of the OSD.
    On the port. I only found one place that carries the 6" flares called Thriller Audio. What is people experience with them in terms of shipping time, etc.
    Does regular 6" PVC fit these flares or do I need to buy their tubes and connectors also? Do I really need the flares? They are pretty expensive for some cheap plastic.
    Finally, I am worried about clamps. Right now I do not own any. I probably won't build to many more speakers, so I would like to avoid a big investment here. What is the minimum I could get away with? How many and what size/type clamps should I buy?
    Thanks!
  • WillyD
    • 675
    Do you happen to live anywhere near Charlotte, NC? I have a couple of 24" tubes.
    • Adam321
      • Jun 2007
      • 37
      No,
      I am in New Jersey, but thanks anyway. I found a couple places that sell the 24" tube and 18", which is to small. But, they would only sell it in 12 foot lengths. The prices ranged from $104 to $150 for the 12'. So, for me it would be more work, but a lot cheaper to go with MDF, and HD is only a few mile away.
      BTW, I did not mention that I would be using the 15" TC-2000SVC as my driver.
        As per the page with the Clio testing it's 18.56Hz
        It would be impossible in the AS-15 box unless angles were used in the port.
        I don't have a scale it will fit on, my guess is 250+lbs
        The only surfaces that 'need' to be MDF are the exterior ones, all the unseen materials could be OSB, (I'd use 3/4")
        I don't know if the plastic is "cheap" or not. The reality is the ports should be flared when using 6" diameter with a high excursion 15" driver.
        For specifics regarding the Thriller flares you should ask them.
        Sorry but I don't keep an inventory of what kind and how many clamps I use in a project.
        If you don't plan on ever building another speaker, you're probably better off paying someone to build the box for you, that way you avoid the investment in tools entirely.
        • WillyD
          • 675
          Regarding Thriller Audio, I've had a good experience with them, as far as service and shipping is concerned.
          • PoorboyMike
            • 637
            Thanks!
            You could always "screw it and glue it". Do you own a drill?
            I've also used an old set of cast iron weights when I didn't have enough clamps. Anything heavy would work, like bricks or even big rocks. You can get by without clamps if you have to.
            • Bent
              • Sep 2003
              • 1570
              here's a drawing of what I built. I didn't use hardly any clamps - screws and glue for mine.
              I attached an Adire Audio ADA 1200 plate amp on mine, it weighed 260 pounds with a Blueprint Designs BP-1503 installed.
              Last edited by theSven; 06 July 2023, 21:07 Thursday. Reason: Update image location
              • Adam321
                • Jun 2007
                • 37
                Thanks for all the replies. I was wondering if I could just use screws to hold it together while the glue sets. What type of screws would you use? Deck screws or maybe sheetrock screws? What is the best type of glue for laminating MDF and/or OSD? Would Gorilla glue or Liquid nails work?
                BTW, I do have a drill. The rest of the tools I would have to borrow. But not too many people have those big clamps.
                I was going to buy a new saw blade for my circular saw and build a saw guide to cut my box pieces. Any recommendations for the type of blade I should buy to cut MDF for a 7-1/4" saw.
                Thanks again.
                • PoorboyMike
                  • 637
                  It really doesn't matter what screws you use. They are just holding the pieces together until the glue dries. Regular wood screws or even drywall screws would do the trick.
                  I use Titebond glue on everything.
                  Don't spend too much on the blade. MDF wears them out fast. Just get a decent carbide combination blade.
                    • 5204
                    See the post I just finished on Glues. According to Fine Woodworking, use regular old wood glue.
                      Laminate the panels together with Titebond II or similar. Use a paint roller to apply it. Take everything and anything you have that's heavy to apply weight while the panels sit flat on the floor to dry.
                      40-60 tooth carbide blade
                      Coarse thread drywall screws (predrill the holes)
                      • DeanP
                        • 175
                        I built about 14 speaker cabs using the following:
                        I use sheetrock 1 1/4" screws('cause thinner shank);pre drilled with 1/8" 'cause mdf likes to split! After the glue dries, I either countersink the screws and leave them there or I remove and fill them with wood filler.
                        I use about three quick grip type clamps to hold while I drill and screw and during assembly. Remove clamps after glued and screwed. :T
                        • Adam321
                          • Jun 2007
                          • 37
                          OK, change of plans I was able to aquire a piece of 20" sonotube. I will start a new thread with new questions on this design.
                          Thanks for all your replies. I think after reading Thomas' replies I got a little scared about building the AS-15 for my first DIY project. Especially the fact that it would weigh in at 250 lbs. 8O Also, I could go for the lower tune I was looking for much easier with the Sono.
