I'd like to build a sub to cause I like to build things and I feel I can do it for less while adding some WAF finishes to the sub.
My goal is to have a sub primarily for HT (95%) that's tuned to 20hz. My family doesn't like it loud but I'm trying to convert them.
I'd like to keep my budget for the driver and amp around $400. I'm not that concerned with the cost of MDF, port, supplies as the finish is yet to be decided by my wife. I'd like to build a taller sub as linear real estate is mucho valuable in our current setup. The size of the driver i thought would be good is was 12". I looked at TC Sounds and eD but don't know enough to know which one is better.
Is it possible to build a sub with those goals at a cost of $400 for driver and sub? What driver do you recommend? I thought of a BASH amp but read somewhere about the one or two resistors needing to be replaced (probably need to read a little more). I don't know enough about the Dayton, eD, or Rythmik amps to comment on.
I'm not at all opposed to copying someone else's as my passion is in the construction end of building a sub.
