Help with RSS315HF-4 12" & LT ckt
  • Marzen
    • 302
    I wanted to incorporate two methods I've been interested in, using mostly left over parts. So I thought I'd have a run at a LT sub with curved sides.
    I'm having trouble with the LT part in regard to calculating my initial target enclosure size even before applying the LT circuit. Is there a walk thru on the web for this?
    I think I'm shooting for a flat ~70% max excursion from 20hz up to around 40hz in an attempt to end up with a critically damped Qb with extended bass response while using a small enclosure that would normally have a high Qb response peak.
    Parts on hand are...
    Dayton RSS315HF-4 12" High Fidelity Sub woofer
    Rythmik Audio A250 watt Amp - Basic
    Add on parts..
    Rythmik Audio Half Installed Linkwitz Add-on Board for A250 amps
    I like the look of this Phil Jones cab...
    -Ward
    What if the Hokey Pokey really IS what it's all about?
  • nayr
    • 46
    That IS a nice looking cabinet. It also looks like a lot of work to build! 8)
