Hi all, I am currently using an Audiomobile MASS 2012 S4 (single 4 ohm voice coil) in a ported enclosure for my home theater. I also have a dual voice coil version sitting unused and was thinking about adding it as well - you can never have too much bass . Is it reasonable to use two separate subs in home theater? Will they have bad cancellation effects if placed in opposite corners, or side by side? Do their slightly different T/S params matter? I would probably just wire one coil from the dvc version so that I could use a 4 ohm amp.
Dual voice coil specs:
Single voice coil specs:
Thanks!
Brian
Thanks!
Brian
