I will have a 5.1 home theater set up. I am currently building the NatP's mtm design with the dayton reference mid and aluminum tweet. I need a center channel. I have a few options.
1. Could just build a 3rd NatP and lay it horozintally. It is a perfect match to the right and left channel NatP's, but I know a mtm is not optimal.
2. Could use the Modula MT, using dayton reference mids and aluminum tweet. It is cheap, and can be done easily.
3. Could go for the Modula MTM center channel, using the scan speak tweeter. 2 Problems with this is that it uses a different tweeter, and may not be matched to the NatP's perfectly. Also, it is expensive to build.
4. Could do a wmtw design, which is optimal, but expensive and very large. I dont want to do this option at this time because of the size.
My preference would be to do the NatP's for center channel because I am already building the NatP's for left and right channel, and it it would be a perfect match.
Would the Modula MT or the Modula MTM center channel be that much better than doing a NatP center?
Thanks for the input.
